Harley Windsplitter 10" cut-down
Old Apr 20, 2014 | 12:20 PM
AlanStansbery's Avatar
AlanStansbery
Default Harley Windsplitter 10" cut-down
I installed the 10" Windsplitter on my '14 SG. It was lightly tinted. It worked pretty good for cutting the buffeting, better than the 7.5" Windsplitter…but I didn't like the look. It was a little too tall and I liked the darker smoke of the 7.5".
I cut one inch off the top and painted it black versus trying to tint it (DupliColor Bumper Coating, because it flexes a bit). It works fine, I can see over it (I'm 5' 11"). I also put a strip of door edge-molding over the cut. I suppose you could tint the shield if you prefer. And if you do this, I recommend getting someone to cut it with a glass cutter (versus my method of a Dremel).
Of course if you buy what you want/need in the first place you'll save yourself some time. I know LRS makes a 9", and probably others. But I was already committed to the 10" so decided to try to make it suit me.
Alan
Attached Thumbnails Harley Windsplitter 10" cut-down-p1020566.jpg   Harley Windsplitter 10" cut-down-p1020567.jpg
Old Apr 20, 2014 | 12:35 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
next time cut the bottom of the shield,leave the top edge alone.
Old Apr 20, 2014 | 12:41 PM
mkguitar's Avatar
mkguitar
....and if you are a frequent windscreen swapper, cut the keyholes a little wider, makes for easy quick swaps.
easier if you have 2 windscreens, that way you can use one to trace the cut line on the other.
dremel, jigsaw, i use a rotozip. takes about 10 minutes incl coffee.
messy though
-when I swap seats, I swap the windscreen to match seated height, so a have 3 cut down windscreens
this works really well on stock windscreens
mike
Old Apr 20, 2014 | 01:20 PM
CSMHOG's Avatar
CSMHOG
Looks good. I've been painting the inside of my 7.5 windscreen for about six years now. Love it!
sgnden
Oct 16, 2018 05:54 AM
steelerdude1
Nov 10, 2014 05:49 AM
frozensoul
May 14, 2014 08:45 AM
uplandpinter
Apr 26, 2014 06:00 PM
troop
Aug 23, 2010 09:24 AM
