Shutdown procedure?
Old Apr 24, 2014 | 04:32 AM
  #51
'05Train's Avatar
'05Train
I dump the clutch in 6th gear so the bike stalls. No wear on any switches that way.
Old Apr 24, 2014 | 05:50 AM
  #52
skratch's Avatar
skratch
Originally Posted by wurk_truk
This is 100% correct and was terrible on 08s and 09s. 10 and up to a lesser degree but not totally 100% reliable to use the kill switch.
Anyone with drive by wire really should train themselves to use the ignition switch as opposed to the kill switch for this reason.... having the TPS NOT at zero causes issues folks whine about on here and it is such a simple fix, too.
or maybe, just maybe, if you have tbw, instead of training yourself to use the ignition, you should train yourself to flick the kill switch off without cranking on the throttle.
in the 5 years that i've owned tbw bikes, i have never had that problem with fast idle. and i always use the kill switch.
i don't know the real reason for it, but what i was told was that it was there so that you could shut your bike down without having to take your hands off the controls. sounds logical to me, whether or not it's true....?
Old Apr 24, 2014 | 06:09 AM
  #53
Jackie Paper's Avatar
Jackie Paper
My Harley's TPI (Throttle position sensor) has only got mixed up on time in 40K. I cold started it in gear on a downward slope. It lugged forward a little more then usually (probably about 4-5") My first stop a few miles later had a 1300 rpm (about 300 high) Cutting it off reset it and this has been the only time it did it.
Old Apr 24, 2014 | 06:32 AM
  #54
sfcmo357's Avatar
sfcmo357
Where is the kill switch? J/K guys!!
Old Apr 24, 2014 | 09:29 AM
  #55
SBates08's Avatar
SBates08
Seriously!?!
2010 Limited with some stuff
Old Apr 24, 2014 | 10:19 AM
  #56
bellgnte's Avatar
bellgnte
Originally Posted by SBates08
Seriously!?!
I know....6 pages of posts on shutting down a motorcycle. Kind of funny
Old Apr 24, 2014 | 10:30 AM
  #57
TriGeezer's Avatar
TriGeezer
My shutdown process is so automated, I had to do it slow to even know what it was. Yup, I hit the kill switch, then turn off the ignition. Coming into my garage, I actually hit the kill in the driveway, and coast into the garage. That reduced exhaust in my garage. This would be a pain to do with the ignition switch. I also got used to using the kill switch on bikes where it was more difficult to get to the ignition switch.
Now for more important questions:
- do you start your bike before saddling up?
- do you put your helmet on before you start the engine?
- do you wear fingerless gloves in the summer?
Old Apr 24, 2014 | 11:23 AM
  #58
Very High Plain Drifter's Avatar
Originally Posted by SR90
I have a routine. I pull into the garage or anywhere else I'm stopping, hit the kill switch, put the jiffy stand down, turn off ignition switch, and hop off the bike. It's habit. The one time I deviated from that routine I forgot to put the jiffy stand down....
Exactly mine too.
Wear and tear on the switch? You have to be kidding. Modern microswitches (hell, even antique ones) can stand thousands and thousands and thousands of cycles. How often do you replace the light switches in your house? Think those are actually any more durable than the one fitted to your bike?
Old Apr 24, 2014 | 12:45 PM
  #59
CyGlide's Avatar
CyGlide
Originally Posted by Eyeball Kid
On a side note...
Does anyone, when riding with a couple good friends, reach over and hit your buddies kill switch as a red light turns green?
Such a hoot! Riding away as he blocks traffic, and gets left behind.
When I used to ride rockets with buddies we did that stuff all the time. Now we are all older not so much. Something about riding a $25000 bike as opposed to a $10000 bike. If someone gets close enough to hit my kill switch on my SG I'll beat em off with a big stick.
Old Apr 24, 2014 | 01:10 PM
  #60
CRF's Avatar
CRF
Originally Posted by mmcbeat
If someone did that to me, I would never ride with them again.
well you have no sense of humour then...
