Brake line replacement question
Old Apr 24, 2014 | 10:27 AM
Nilla's Avatar
Nilla
Default Brake line replacement question
I swapped my stock lines for Drag Specialties part no. 17412638 (+10) when I installed my apes.
I'm going in another direction and need a stock length line... can I just replace the top section on this style? I'm not finding much info online that has a definitive answer. Also, my current line has a straight banjo from the master... I'd like to run one that has a 90 degree bend so it follows the contours of the new bars better.
I'm having trouble nailing this stuff down, most of the retailers are either using stock photos of not even the specific part #, or the info isn't even stated.
Any help much appreciated.
Old Apr 24, 2014 | 10:32 AM
bagman1's Avatar
bagman1
Yes you can just change the top line as long as the three way manifold has threaded ports. Look up drags fatbook online or consider jp specialties or dennis kirk. They have hundreds of configurations for brake lines and styles.
Old Apr 24, 2014 | 10:39 AM
Nilla's Avatar
Nilla
They're not the threaded ports. The manifold and metal line portion is one casting. I was hoping there was a method to separate the flex line from the hard line section. If you google the part number I posted you can see what it looks like.
Old Apr 24, 2014 | 10:41 AM
TeamMudd's Avatar
TeamMudd
Look into the Magnum brand lines. those are the ones i put on mine when i did the apes. they have a 2 piece set up where you can get the style you want from the caliper to the forks then from the forks to the master cylinder!
Old Apr 24, 2014 | 11:12 AM
bagman1's Avatar
bagman1
Than youre screwed sounds theyre just like the stock welded setup. Magnum chromate or goodridge are your options
Old Apr 24, 2014 | 11:25 AM
Nilla's Avatar
Nilla
Yep, looks like new stuff on the way. Oh well, thanks fellas.
Old Apr 24, 2014 | 11:29 AM
TeamMudd's Avatar
TeamMudd
i'm very happy with the 2 piece set of from Magnum... easy install, no issues!
cmshdfx4
Apr 2, 2016 09:31 AM
LooseMoose
Mar 9, 2013 03:30 AM
piercings4_u
Jan 21, 2011 07:49 PM
Eyespy
Aug 9, 2009 08:24 PM
jbweld
May 24, 2009 07:55 AM
