Antenna question. Help please
Old Apr 24, 2014 | 03:16 PM
gjcusa's Avatar
gjcusa
Default Antenna question. Help please
So I'm doing my rear fender on a 13 street glide. Is the cvo mount for the antenna different or just positioned in a different hole? I'm most likely going with top shop sick Rick cvo fender. I know the cvo antenna seats lower and comes out near the strut cover as opposed to the hole in my sg fender. Or should I just go with hd hidden. Thoughts? Thanks in advance on any advice
Old Apr 24, 2014 | 05:27 PM
SG-Jay's Avatar
SG-Jay
Just do the hidden one, you don't want to mess up a sick looking fender like that with an antenna.
Old Apr 24, 2014 | 05:49 PM
dansflhti's Avatar
dansflhti
The CVO antenna mount bolts to the left fender strut cover.
Old Apr 24, 2014 | 10:02 PM
gjcusa's Avatar
gjcusa
I know the hidden is the way to go in terms of looks. Just heard so many negative things about the hidden antenna in the fairing. How is the installation to do the internal antenna ?
Old May 13, 2014 | 01:30 PM
RobNation's Avatar
RobNation
Stage II
Wink Internal Antenna
The install is 10-15 minutes just remove the outer faring and plug it in and position it, but IMO the internal Antenna has lousy reception. The bike will look nice sans the fender antenna but whats the point if it does not work the same. You would think we could get a internal faring mounted antenna that works well, but not so much. If you want to try it email me your address and you can have mine for free just pay the actual shipping
Old May 14, 2014 | 01:53 PM
1CoolZ71's Avatar
1CoolZ71
I took my stock antenna off the mount and put a rubber sleeve around it.
Then I ran in between the fender and strut mount then up under the seat.
Cable tied it in place so it doesn't move.
Reception not as good as stock, but way better than the hidden fairing models
D W K
May 5, 2015 11:51 PM
Rickr01
Dec 17, 2013 07:59 AM
Stew Pidaso
Sep 12, 2013 05:51 PM
Stew Pidaso
Apr 5, 2013 11:19 PM
Jerry L
May 23, 2012 04:57 PM
