Up-graded clutch for SG
Old Apr 26, 2014 | 03:26 PM
1BADHD's Avatar
1BADHD
Default Up-graded clutch for SG
Good day all,
I have a 2012 SG, added a set SE-204 cams, just had it tuned at 95hp and 105tq...(what a great set of cams) I have noticed the stock clutch slipping a bit when you really get into it. The bike is still under warranty so I was thinking of just paying the extra and getting them to install the SE performance clutch plates. Are they worth it? or is there a good after market clutch that I can install? I do my own work as I installed the cams, so installing a set of clutches shouldn't be an issue.
Any feed back would be much appreciated!
Thanks in advance!
Dave
Old Apr 26, 2014 | 03:33 PM
qtrracer's Avatar
qtrracer
The stock clutch pack is good for well over 110. Put in an SE spring and make sure you have adjusted the clutch as per the service manual, cold. Also I would make damn sure I didn't have any synthetic oil in the primary. I'd have HD formula+ in there or another non-syn primary fluid like drag specialties or rev tech.
Old Apr 26, 2014 | 03:52 PM
1BADHD's Avatar
1BADHD
I will change the fluid over. They did the first service at the dealer and added synthetic to it. I changed the engine oil only after a few thousand km as I'm not a fan of any synthetic oils. I will change out the primary oil this week. Thanks for the info!
Dave
Old Apr 26, 2014 | 04:59 PM
6 gun's Avatar
6 gun
Just a heavy duty Screamin Eagle clutch spring is all you
need to fix your clutch slipping problems. That is all that I
have in my built 103
Old Apr 26, 2014 | 05:05 PM
Gliden's Avatar
Gliden
Probably overkill but I had a Barnett clutch pack installed when I went 106.
Old Apr 26, 2014 | 05:12 PM
dawg's Avatar
dawg
Throw in a VPC and it won't increase the pull like the SE spring will.
Old Apr 26, 2014 | 05:33 PM
qtrracer's Avatar
qtrracer
It'll still may slip till the vpc kicks in at 3k. Late model tourers have a lite spring, like 280 lbs, stock before that was like 340, if I remember correctly.
Old Apr 26, 2014 | 05:40 PM
jeg1's Avatar
jeg1
I have the SE spring in mine and no slip.
Old Apr 26, 2014 | 06:51 PM
dawg's Avatar
dawg
Precisely why I ditched the spring for the -98A spring, heavier but not as heavy a pull as the SE
Old Apr 26, 2014 | 06:57 PM
qtrracer's Avatar
qtrracer
I went with basically the same spring but I can never remember the HD part number, LOL.
