Transmission full
Old Apr 27, 2014 | 10:38 PM
glock221's Avatar
glock221
Default Transmission full
Changed my oil. I run the same oil I always do. Not looking for an oil debate. I used 1 Qt. to fill it. I think it may be a tiny bit overfull (1/8 of an inch over full mark). Will that hurt anything It does clunk in each gear when I shift, but I can't remember if it did it before or not. I know it clunked in going from Neutral to 1st for sure. 13 flhx
Old Apr 27, 2014 | 10:47 PM
texaswiz's Avatar
texaswiz
Originally Posted by glock221
Changed my oil.
It won't hurt a thing.
Old Apr 27, 2014 | 10:48 PM
GriffinDenim13FLHX's Avatar
GriffinDenim13FLHX
Yes it will "clunk" A way to stop the " clunking" in to pull clutch while starting. Then before putting it in gear I hold the clutch for about twenty secs. Then I put it in gear and usually smooth engagement. You will be fine 1 in trans, 1 in primary, 3 1/2 in engine warm up and check should put level right so you do not get blow by out the airfilter.
Old Apr 28, 2014 | 05:12 AM
grbrown's Avatar
grbrown
Each hole has a level to which the oil should be filled, shown in the owners manual, so just fill it to the level! Doesn't matter how much it takes, as long as you have enough. As for the clunk, having owned Harleys for forty years I can confirm they all do it, when engaging first, first thing. Ride and enjoy.....
Old Apr 28, 2014 | 07:03 AM
'05Train's Avatar
'05Train
Pretty sure the manual says 28oz. You've overfilled it, might not be a big deal though.
Old Apr 28, 2014 | 07:16 AM
crimson13's Avatar
crimson13
The manual says to start with 28oz then add if necessary. I don't think 32 is gonna hurt. You could always drain a little back out.
Old Apr 28, 2014 | 07:18 AM
grbrown's Avatar
grbrown
Talking
Ah, the infamous book.......
Old Apr 28, 2014 | 07:23 AM
Jackie Paper's Avatar
Jackie Paper
The overfilled primary is what causes the clunk (it drowns the clutches and tends to make them drag more even with the clutch pulled in). 1/8" on the transmission dip stick is not going to hurt anything. If it was too full, when hot, it could come out the vent hose which is not good. However, lets face the facts, I know you are going to loose sleep over this, yell at the wife and kids and probably kick the dog. So why not just wait till it's cool and take a 3 big Hardee's red straws and stick down in there and hold your thumb over the end and pull a few ounces out. Or just use the wifes baster, it's still clean oil. (don't tell Susie, but I guess that's another problem)
Old Apr 28, 2014 | 07:34 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Considering how horizontal the transmission dip stick is, it makes reading it for accurate values highly suspect. Over filled might cause a bit of foaming, but I highly doubt it.
Old Apr 28, 2014 | 08:27 AM
Boomer1143's Avatar
Boomer1143
When changing my transmission oil I always drain and then refill with a full quart. No problems.
ddsarif
May 30, 2016 08:37 PM
NYdyna
Aug 22, 2010 10:14 PM
dlnp22
Sep 9, 2009 12:26 PM
177hdking
Jun 11, 2009 06:26 AM
bluethunder1949
Sep 6, 2008 03:49 PM
