transmission grind
Old Jun 11, 2009 | 05:40 AM
177hdking's Avatar
177hdking
2nd Gear
Smile transmission grind
every once in a while my transmission grinds when downshifting to first at a stop. Could it be I'm shifting too soon ?
Old Jun 11, 2009 | 06:14 AM
Notgrownup's Avatar
Notgrownup
Grind??? doesn't sound good if you ask me....Try going to severe gear 75w140 oil see if it helps.
Old Jun 11, 2009 | 06:18 AM
bigjames19's Avatar
bigjames19
You could be downshifting to 1st with too many rpm's causing the grinding sound.
Old Jun 11, 2009 | 06:25 AM
dgriffith's Avatar
dgriffith
Maybe, first make sure the clutch is adjusted properly and you are fully pulling the lever. Second, If the speed is too fast it will clunk sometimes. If the oil in the primary is dirty or too thick when cold, it will cause a slight grind, because the clutch plates are sticking together. As suggested above, try a gear oil in the transmission. Like Mobil 1 75/140, or in my case, Redline Shockproof Heavy. It can be ordered online or bought at most off road bike and metric shops. Any and all of this will help. Ride safe and welcome to the Forum. Dan
Old Jun 11, 2009 | 06:26 AM
KopperTop's Avatar
KopperTop
Welcome. How many miles on this mystery bike? When was the clutch last adjusted?
Hotrodnils
Jul 10, 2019 12:44 PM
polbit
2018+ Softail Models
Feb 7, 2019 09:47 PM
ddsarif
May 30, 2016 08:37 PM
Topspin
Dec 29, 2008 10:09 PM
Matrix
Feb 15, 2007 02:13 AM
