cold start issues
Old Apr 28, 2014 | 07:39 PM
EdandGrace's Avatar
EdandGrace
Default cold start issues
13 SG with recently installed SE stage 4. Now have some issues with cold start. Will start but not on the first crank. Used to fire right up. Starts on second or third try. Once warm will fire right up. Assume something with the tune but would like some ideas before I approach the dealer who did the work.
Old Apr 28, 2014 | 09:17 PM
Pappy1's Avatar
Pappy1
I have a 09 96ci street glide....same way...before the pipe and heavy breather and race tune it fired up first pop and run fine....98% of the time it still hits first try but runs rough for a few sec and lopes slow and sometimes dies...after a few seconds when it gets a chance to warm for a min it does fine...runs fine and strong all day....been on the dyno twice.....just never did it until the mods...
Old Apr 28, 2014 | 10:09 PM
mkguitar's Avatar
mkguitar
ask the dealer.
many tuners or ignition systems require a couple of cranks before the plugs fire
our bikes do not have large flywheels and forward momentum has to be built up. otherwise the piston can go backwards "kick back".
so ask them
Mike
Old Apr 28, 2014 | 10:20 PM
rufasim's Avatar
rufasim
I have a 12 vsg with vh mo's, se eavy breather, and a pcv. since I put on the heavy breather and pcv tuner mine has a hard time starting when cold, just as described as above. When above 45, starts up no problem. When running, it runs great.
Old Apr 28, 2014 | 10:50 PM
mmats69's Avatar
mmats69
I have the same issue when cold. Like it's not firing when it's suppose to. It has even backfired through the air cleaner. Getting a CVO fender put on and the tuner is gonna look at it while it's there. Said something about changing the way it fires on a cold startup.
Old Apr 29, 2014 | 07:45 PM
EdandGrace's Avatar
EdandGrace
Originally Posted by mkguitar
ask the dealer.
so ask them
Mike
Sure, wanted to be a little educated before I spoke to them. So, you're thinking with the stage 4 this is expected?
Old Apr 29, 2014 | 08:08 PM
Pappy1's Avatar
Pappy1
Must be a common problem when you upgrade.................so it seems
Old Nov 21, 2014 | 04:16 PM
Ben Lemmert's Avatar
Ben Lemmert
6th Gear
Same issue here with my 09 RK stage 4. I was suspecting a tune problem.
Old Nov 21, 2014 | 04:36 PM
Mr HOG's Avatar
Mr HOG
I have a 107 and it's pretty much the same way. It always starts after 2-3 revolutions when cold. It think that's pretty normal.
stackovrflo
Apr 4, 2012 09:51 AM
PWFD
Sep 17, 2009 01:25 PM
B_R_OO_K_L_Y_N
Mar 19, 2009 05:40 PM
OutlawBagger
Feb 27, 2009 06:40 AM
