I prefer a 120/70/21 Michelin Commander on my ride. The stock tire (Dunlop) is hard as a rock in my opinion. Of course that is my opinion. If you want matching tread that is the only way to go with a stock rear if the bike is 09 or newer.
I also have been riding a while on all kinds of bikes with spokes. Only one I really had trouble with was the rear on a Frankenstein rigid dresser. It would snap a spoke once and a while but it never left me anywhere because of it. Just keep an eye on them.
I ran the Midwest fat spoke on my Dyna and am running a DNA fat spoke on my Road King . So far, not an issue with either one. And to my knowledge, I don't even think its possible to true one of these fat spokes. At least in the traditional old school way. Ride Wright makes a great wheel. You can't go wrong with their stuff.
I like the spoke look too. The only additional maintenance (besides cleaning) is making sure the spokes remain tight. Just a tap with a screwdriver is all you need to do.
yep, run ride wrights tubeless and have never had a single issue, no truing, abnormal leaking, nothing.
Let whoever changes your tires know hat the rim is sealed. Had the seal busted on a wheel I had like that getting a tire changed (before I worked at a wheel shop). Been tubing it with spokes ever since. But to each their own. No one thinks about it until it happens to them.
Spokes look great and certainly have a classic look.
You'll spend more time cleaning em than repairing em by a long, long shot.
If properly built they will last..
To maintain them I suggest that after a thousand miles or so to go around the wheels and strike each spoke with your "Spoke Wrench" and listen to the tone....
They should all have relatively the same tone...
Any that sound flat are a little loose
I go around the wheel and make sure that I don't have more than a few of them "Loose". I'd then give each one about 1/4 - 1/3 of a turn. Use a little common sense while torqueing them by going to opposite sides as much as possible.
if during the initial inspection you find a cluster of loose spokes in an area then you should probably do some investigating.
Other then cleaning you shouldn't have a lot of maintenance if you buy a quality spoked wheel. Just don't hit any major potholes, but those will jack up a non spoked wheel as well.
If you want the look of spokes but a solid wheel - check out wheels like the Primo Cali or the Thomason Performance Spokin
