Bike Tronics
Old May 4, 2014 | 06:04 PM
wrenchguy24's Avatar
wrenchguy24
Default Bike Tronics
Anybody have there handle bar controls quit working??
Bought my set last October and since Iowa weather sucks I have only rode about 200 miles. Yesterday I found my left volume control up would go down and when pushed
wouldn't do anything.
I see on there website they don't sell the BT1002 anymore its now the BT1005x
I know it is under warranty!! Ill call tomorrow!!
Old May 5, 2014 | 12:19 PM
DocDyna's Avatar
DocDyna
Default Couple of times
Mine has stopped controlling a couple of times. Both times I unhooked my battery for a couple of minutes then hooked back up and it worked. First time I discovered this when replacing a old battery that was failing. I blamed the problem on low voltage. Second time was during winter before I hooked up my tender, same issue, battery got low the hand controls quit, even after charged back up, so I just guessed and unhooked cable for a couple of minutes and whamo it worked ok after re-connecting. Low supply voltage must lock up the Biketronics unit.
Old May 5, 2014 | 12:23 PM
UltraNutZ's Avatar
UltraNutZ
got a powervison?
Old May 5, 2014 | 01:47 PM
fat daddy's Avatar
fat daddy
Originally Posted by UltraNutZ
got a powervison?
Why would you ask about powervision? Reason I ask is that I have one on my bike and also the bike tronic kit and I haven't had an issue yet.
Old May 5, 2014 | 01:49 PM
UltraNutZ's Avatar
UltraNutZ
starting to see issues where when the PV is IN GAUGE MODE, it's interfering with handlebar control modules. ALL OF THEM, not just Biketronics.
Take it out of gauge mode and all is fine.
Old May 5, 2014 | 06:35 PM
wrenchguy24
Yes
I have a Power Vision
Hmmm ill try that and see what happens !!!
Old May 5, 2014 | 06:57 PM
nick@nite's Avatar
nick@nite
Yup i've had a few problems with mine and had a couple of modules replaced and its acting up again.
Old May 5, 2014 | 07:09 PM
Geezr Glidr's Avatar
Geezr Glidr
Guess I'm one of the lucky ones. Have had mine on for a little over a year, and haven't had a problem.
Old May 6, 2014 | 12:36 AM
DeadManWalkin's Avatar
DeadManWalkin
Mine keeps cycling the volume up an down by a notch or two every couple of seconds. Can really hear the difference but I see my screen change out of my peripheral vision. It's annoying.
Old May 6, 2014 | 05:59 AM
UltraNutZ's Avatar
UltraNutZ
turn down the AVC. it's set too high
