Dead battery??
I now have it hooked to the tender, hoping it will charge. When I turn the switch, the tender doesnt recognize its attached, but when it's off, it shows it's charging.
My question/worry is could it be the regulator? I had planned on trading for a new SGS next week, so the timing for this is horrible. For those of you who are familiar with battery systems, what do you think this is and what are your recommendations? Thanks in advance...
If I were you I would pull it out and take it to your local auto parts store. There they can properly charge it and test it's condition. You can't diagnose a charging issue without a properly charged and functioning battery.
tender maintains a charge
charger charges
jump starting can destroy your charging system
pull the battery, charge it, test it and check the cables too.
mike
the right answer, and provide folks with lots of help.
Thanks for your contribution to the forum!
peace
1.) bad chemistry, sulfated plates etc. it is just worn out
2.) open circuit; a 12 V battery has 6 cells which internally have a buss bar or "jumper" wiring them in series- on occasion, these may break or part.
3.) shorted; an internal short circuit- in which case the battery may burn.
or discharged;
a.) battery drained by load being left on
b.) discharged because of electrons flowing between the poles through dust on the battery case
c.) bad chemistry
d.) etc.
If the battery is "jumped" and the motor started, the charging system is now being asked to supply power for the bike and lights- and also the drag of a discharged or duff battery.
If the total load exceeds the capacity of the charging system, it may overload and fail.
and a $100 problem becomes a $600 problem
this also applies to automobiles, although most automobiles have the alternator where it can be cooled by air ( most have a cooling fan built in) and have an alternator of much higher capacity.
I would only jump my own bikes if I had first diagnosed the fault or if I was stuck in BFE.
More than one rider has been to the autoparts store and rigged up a battery on the pass seat with bungee cords and extended cables.
on one of my old Panheads, I had a 9 volt battery clip and in emergency could run the ignition system off of that for about an hour ( no lights)
some of you may have seen my post last year on a neighbor who spent $1300 on repairs, when the fault was a $12 cable. the bad cable caused intermittent resistance/ open circuit and burned up a couple of charging systems and 3 batteries
mike
mike
The alternator on my bike pushes 45 amps, and I'm sure the regulator is designed to cope with that.
