Dead battery??
Old May 9, 2014 | 08:55 AM
larsfum's Avatar
larsfum
Originally Posted by gkbailey78
Thanks for the input guys. I pulled the battery and took it to have it charged. Brought it home and it fired right up. It will stay on the tender while not being ridden. Hopefully there will be no more issues as I plan on trading it very soon for a SGS.
Did you have it tested to see if it was good? You still haven't found what discharged the battery in the first place. You may find yourself trying to start it one day, and scratching your head when it doesn't fire up.
If I were you I would do a full system test.
Old May 9, 2014 | 11:11 AM
mkguitar's Avatar
mkguitar
Originally Posted by Big Trev
The alternator on my bike pushes 45 amps, and I'm sure the regulator is designed to cope with that.
If a duff battery is drawing ∞ amps due to short, then your charging system blows up.
a dead/ discharged battery wired into the system does not have a neutral effect, it is a "load" placed on the system- as the system tries to maintain 14+ volts.
The battery will continue to be a load until the battery is charged to about 80%+ at which point it will maintain a charge ( volts) at a level close to equal with the power being produced by the charging system
The stator is enclosed inside a hot environment- unlike an auto alternator it is less able to shed heat
heat builds resistance in the wiring of the stator, resistance results in ...more heat and a runaway effect can burn the stator wiring
Mike
Old May 9, 2014 | 12:05 PM
gkbailey78's Avatar
gkbailey78
They tested the battery at the dealership and the battery tested good. I brought it home, installed and rode last night
I thought about doing the full system test, but I plan on trading next week and don't want to invest in doing more work before trading unless it fails again.
Old May 9, 2014 | 12:29 PM
mkguitar's Avatar
mkguitar
...invest in doing more work before trading unless it fails again.
if you keep the bike, a discharged battery will only recharge to about 60% of it's previous capacity
( so if rated for 300 CCA, expect that you may now have a battery with a real reserve of about 175 CCA).
so if you keep it, keep an eye on that and be prepared to order up a new one.
another common problem is poor connections at the other end of the battery cables- the easy time to check this is when the battery is out of the bike
mike
Old May 9, 2014 | 12:38 PM
mwegryn's Avatar
mwegryn
I doubt that a battery tender will be able to help you much. A tender is designed to maintain a charged battery, not to recharge a drained one.
Get it checked. I'd be curious to know the actual manufacture date. Did you keep it on a tender? I plug mine in every night when I park it, it only takes a few seconds.
bootcampsam
Sep 18, 2016 09:28 AM
Oscarthegreat
Jan 4, 2015 01:37 PM
jefla
Jun 29, 2014 01:30 PM
bikersally
Nov 21, 2012 11:29 AM
waycool'76
Feb 8, 2010 04:05 PM
