Tweeter install question
Old May 15, 2014 | 08:55 PM
rwb1's Avatar
rwb1
Default Tweeter install question
Finally decided to to the audio project I have been putting off....amp and speaker upgrade in my 2013 Road glide.
Got the speaker adapters and speakers mounted..(pain in the *** to get the adapter rings to mount up)...took out the oil/air temp gauges to mount the tweeters and of course the holes are to big.
What is the best, most secure way to mount the tweeters in the hole's ?
Also, where did everyone mount the crossover's..? Mine are a little smaller than a deck of cards.I don't really want to drill into the inner fairing at all...was thinking about some industrial hook and loop velcro...not the fuzzy stuff but the heavy duty stuff like they us on an e-z pass, or whatever you guys call that device, you mount on your windshield that charges your credit card when u go through a toll booth.
I did a search but really only found a few random threads.
thanks for the help
Old May 15, 2014 | 09:58 PM
0ldhippie's Avatar
0ldhippie
Get the gauge block-offs (75106-96a) and cut them for the tweeters.
My crossovers are mounted to the speaker/batwing braces.
Old May 16, 2014 | 06:59 AM
rockajet1's Avatar
rockajet1
What he said about the gauge block offs. I used a hole saw (I think 1 1/2") to cut them out and then trimmed them just enough so that the tweeters friction fit. Worked perfect! I used Velcro to attach my crossovers.
Old May 16, 2014 | 08:29 AM
hd_rolling's Avatar
hd_rolling
What tweeters did you buy? My hawg werks tweeters snapped right in and fit like they were meant to be there, I just zip tied my cross overs in to the other wires and they have stayed in place for a few years now.
Old May 16, 2014 | 08:31 AM
rwb1's Avatar
rwb1
Thats what I thought...just wanted to make sure....
HD Rolling, I bought a set of Rainbow components...tweeters are about 1/2" to small. I have used Rainbow's in a few cars in the past and ar by far the best speakers I have heard...prolly sound like crap on the bike but...lol
Anybody use foam baffles or any other dampening material around the speakers?
Appreciate the help.
Old May 16, 2014 | 08:52 AM
hd_rolling's Avatar
hd_rolling
I didn't see you mention an amp, are the speakers you bought for the 2ohm Harley system or did you add a new head unit to run 4 ohm car speakers?
Old May 16, 2014 | 09:09 AM
rockajet1's Avatar
rockajet1
I'm using Focals.
Old May 16, 2014 | 10:10 AM
SDVmnt's Avatar
SDVmnt
I purchased two new gauge mount pods. Used a hole saw on those to enlarge. Used Hot glue from the back to hold the tweeter in the gauge pod. Car audio shops do the same thing.
I'm running Phoneix Gold R65CS components.
Old May 16, 2014 | 02:59 PM
rwb1's Avatar
rwb1
I am installing a RF pbr 300x2....
Has anyone mounted the tweeters in the steel mesh grilles ?
Old May 16, 2014 | 08:07 PM
rwb1's Avatar
rwb1
I'm running 4 ohm speakers on the 2 ohm system which should be ok as I understand it....less power but wont hurt anything ?
Bafflingbs
Audio Systems
15
May 9, 2019 11:26 AM
Biggzed
Audio Systems
Mar 15, 2019 08:28 PM
Indawynd
Audio Systems
Feb 24, 2019 01:41 PM
PHREDD71
May 27, 2009 05:14 AM
Hoffy
Mar 9, 2009 07:12 PM
