Handlebar Controls Question
Old May 16, 2014 | 08:02 PM
KDUBYA's Avatar
KDUBYA
Default Handlebar Controls Question
Does anyone know what the switch is for that is behind the clutch lever on a 2007 Street Glide? I bought a chrome control set on ebay and the kit they sent me doesn't have the hole for this switch. The company I bought the kit from says there is no switch on the clutch side and I MUST be looking at the brake side!! I even sent them pictures!!
Old May 16, 2014 | 08:58 PM
0ldhippie's Avatar
0ldhippie
It tells the ecm the clutch is disengaged. Start in gear/turn off cruise. But I thought it started in '08??
Old May 17, 2014 | 08:57 PM
KDUBYA's Avatar
KDUBYA
Thanks for the help. I have no idea what year they started using them. mine is definitely a 2007. I'm finding it hard to find a chrome control kit with the hole for that switch.
Old May 17, 2014 | 09:54 PM
dochawken's Avatar
dochawken
They said you must be looking at the brake side???? Lol...makes you wonder doesn't it..
Old May 17, 2014 | 11:08 PM
Thickraybans's Avatar
Thickraybans
I couldn't find controls I liked that had the clutch disengaged switch. This switch is normally closed (hot) when the lever is out, and open when the lever is pulled in. I just soldered the ends of the wires together inside the nacelle housing to delete the switch. If you do this the bike will only start in neutral.
fireman_033
Welcome Area Only
14
Dec 31, 2014 12:57 AM
KDUBYA
May 16, 2014 03:16 PM
shortleg
Apr 7, 2014 11:26 AM
cycler
Softail Parts
Aug 28, 2012 06:20 PM
Abbinc83
May 12, 2012 05:47 PM
