Screw ?????
Old May 22, 2014 | 04:18 PM
Fathead2003's Avatar
Fathead2003
Default Screw ?????
Pulled the bike into the garage and found this screw on the floor right where it was parked. Looked all over and cannot find any sign where it came from.
Checked the service manual but did not see an exact screw used.
It is a #30 torx sheet metal 3/4 inch long just under a 1/4 inch diameter.It is kind of greasy.
Recent work done at shop.New tires,fluids,rear rotor and brake pads. Progressive shocks installed.
Bike 03 EG Standard
Any help is appreciated.
Thanks
Old May 22, 2014 | 04:24 PM
cass's Avatar
cass
....try your seat eye on the back fender, might be from there. had your seat off lately
Old May 22, 2014 | 04:30 PM
grbrown's Avatar
grbrown
It's a self-cutting type, by the look of it, the sort of thing that is screwed into a plain drilled hole in a thin metal panel and cuts its own thread. How about your car?
Old May 22, 2014 | 04:32 PM
cass's Avatar
cass
i was wondering that, then i thought possibly the seat.....but you're right, probably goes into some sheet metal.
Old May 22, 2014 | 04:38 PM
QC's Avatar
QC
Did you check to make sure your Flux Capacitor is still attached?
69cj's Avatar
69cj
It looks like a trim screw of some sort. Have you worked on a car in there lately?
Old May 22, 2014 | 04:44 PM
danzio's Avatar
danzio
It looks like a sheet metal screw but if that's a Torx socket in the head then If it is a Torx, and I can't tell from the picture, it would be the first one I've ever seen with that type of thread. (Non-machine screw).
Old May 22, 2014 | 04:46 PM
69cj's Avatar
69cj
A worn Philips could be mistaked for a torx. Esp. if the reading glasses aren't on.
Old May 22, 2014 | 04:47 PM
Ragtop's Avatar
Ragtop
That's the one that goes on the thingamabob, doohickey on the back of the bike.
Should be easy to find the empty hole!
Old May 22, 2014 | 05:16 PM
stroker23's Avatar
stroker23
Possibly a replacement screw for a rivet on the belt guard to the swingarm? I've seen those screws used to fasten plastic/resin parts to metal parts.
