Just installed a set on my 06 flhti after the dunlops went at 10,000 miles. Checked the metzeler site and was surprised to see the pressures listed at 38 psi for the front and 44 psi for the rear tire. I was wondering what other riders were putting in their tires since I thought this was a bit high.
Thanks,
Scott
I run the same as Dalton, 42F and 46-48R. Even with these higher pressures, they still ride/handle better than Dunlops. Most problems with 880's occur when you don't run these proper pressures.
Thanks,
Scott
38F 44R that's what I run as well. Handles nicely.
Thanks,
Scott
That is the very bare minimum air pressure at 70 degrees F riding one up they are recommending.
42 PSI FRONT and50 PSI REAR is for two up loaded at high speed and it is marked on your side walls!
38 PSI FRONT and 44 PSI REAR two up at high speed in 80+ degree weather the tires will cup badly! Metzeler won't mind that, but your wallet sure will
I figured the tire manufacturer knew more about tires than me so I follow their recommendations. From what I've heard on this forum it's better to err on the high side than low (by a few pounds) when it comes to tire pressure regardless of brand.
