Electra Glide Standard wind poblems ?
Later
Can anyone tell me if there has been any wind/buffeting problems with the 06 07 Electra Glide standards ? I have an 07 Super Glide that I can't ride 70 mph because of double vision . I've tried the tank lift and windshield and I still can't solve my problem so I'm thinking about getting rid of the bike and getting a touring model . I did a search but all I could find was info on an SG . Thanks
..try different eyewear.. how many hotrodbikes without windshields are being ridden every day..speed is speed, whether it's a bike, boat, plane..never had a vision issue that wasn't resolved with a change in glasses, also it seems your eyes get used to it and it gets better over time.
Later
You not only have the force of the direct wind attributed to relative speed traveled, but you also are now being buffeted with the compounded wind force of an aerodynamic shape realesing its wind force on to you.
Place your head in any of those vortexes and you will get extreme vibration to the helmet, which in turn will cause you to experiance blurred vison.
Remedies are to find the air bleed over and reduce or eliminate it.
And as been said, everyone believes the helmet buffeting is caused only by air over the windshield.
When in most cases it is actually air under the fairing and up your torso, causing a low pressure area, that then causes the air over the windsheild to vortex right at the breakpoint of the windshield, which then really slams into your head and helmet.
You ever really want to have a learning experiance, spend a day or twoat a wind tunnel, and watch how moving air reacts to shapes placed in it.
It is unreal the difference in height of a 1/16" can make in wind patterns over and around a surface.
And it is also pretty extreme what moving air does once it clears a surface, or aerodynamic shape.
