How much oil do u put in your primary
Old May 26, 2014 | 11:14 AM
  #31
HKMark23's Avatar
HKMark23
From my 2013 manual:
Table 1-9. Primary Chaincase Lubricant Refill Capacity
ITEM
Primary chaincase lubricant
om00114a
CAPACITY
32 oz (0.95 L) wet
40 oz (1.18 L) dry
Old May 26, 2014 | 11:37 AM
  #32
bikerlaw's Avatar
bikerlaw
ITEM
om00114a
CAPACITY
32 oz (0.95 L) wet
40 oz (1.18 L) dry
Really, cause I have the 2013 manual in my lap, and that's NOT what it says.
Old May 26, 2014 | 12:17 PM
  #33
HKMark23's Avatar
HKMark23
Yep, "Really".
As you may correctly surmise, I copied and pasted the data directly from my pdf manual. My 2014 Softail owners manual (same sort of little book you show) says simply 32 oz. with no reference to the 40oz dry. Dunno why Touring and Softail manuals would be different but it seems they are.
Old May 26, 2014 | 01:47 PM
  #34
mmats69's Avatar
mmats69
1 quart. Bandit recommends running it a tad low for their clutch.
Old May 26, 2014 | 01:56 PM
  #35
skiddd's Avatar
skiddd
Ok I'm confused now........... I have a 2009 street glide with a 96ci motor................. how much do I put in when I change the primary fluid? is it 32oz, 28oz, 45oz or any other level someone can come up with?
Old May 26, 2014 | 02:39 PM
  #36
seniorsuperglideE8's Avatar
seniorsuperglideE8
I'll throw one at you, my Dynas use 26 ozs. on a fluid change. Be aware of what models the questions are asked about.
Old May 26, 2014 | 03:42 PM
  #37
NoCoLoco's Avatar
NoCoLoco
38oz according to the manufacturer for a simple drain and fill.
Old May 26, 2014 | 03:47 PM
  #38
Arizona's Avatar
Arizona
'09 and later is 38 ounces. I drain it and refill with 38 ounces.
On '08 and earlier it's 32 ounces.
Old May 26, 2014 | 03:59 PM
  #39
SR90's Avatar
SR90
What changed in '09?
My '07 service manual calls for 38/45.
Old May 26, 2014 | 04:54 PM
  #40
NoCoLoco's Avatar
NoCoLoco
My '07 did as well. Maybe it was the '06 and earlier TC88/5-speed's?
