Name that tune
Old May 25, 2014 | 08:10 PM
scott01's Avatar
scott01
Default Name that tune
This Street Glide sounds awesome but isn't an idle that low dangerous? I've heard the TC motor needs at least 1k rpm to provide sufficient oil flow. Fact or fiction?
Old May 25, 2014 | 08:15 PM
mkguitar's Avatar
mkguitar
oil volume and pressure are dependent on rpm's.
the oil not only lubricates, but is part of the cooling system oil carries heat from the hottest parts of the motor away to be dispersed to the air.
mike
Old May 25, 2014 | 08:16 PM
decencyxdefied's Avatar
decencyxdefied
that thing has a hell of a lope
Old May 25, 2014 | 09:36 PM
scott01's Avatar
scott01
That's what I thought but damn it sounds good
Old May 25, 2014 | 09:46 PM
vtwinbob's Avatar
vtwinbob
if it wasn't for the sound it would be hard to believe it was even running, don't believe I've never seen one idle that smooth.
Old May 26, 2014 | 06:16 AM
jus2anoyu's Avatar
jus2anoyu
My understanding was that it had to be 900 rpms or more to oil properly. I guess there are 2 ways to look at it, they don't idle for long, so what does it matter, or, idle is when they make the most heat, so that when it needs to circulate lots of oil. It sounds good, and the old Evo bikes idled lower than that, often turning on the oil light. Carbed twin cams idled lower as well, so....
Old May 26, 2014 | 06:18 AM
0ldhippie's Avatar
0ldhippie
I have no real knowledge but I believe the oil pressure thing is fiction. Evos/shovels/knuckles all had worse oiling systems than twincams and they had no oiling problems at idle. The "idle" thing with twincams is more about light flywheels and mapping imho.
Old May 26, 2014 | 11:20 AM
crimson13's Avatar
crimson13
That bike sounds good.
ckamin
Sep 16, 2023 10:30 PM
speedwaysteve
Oct 7, 2016 11:17 AM
radudel
Apr 18, 2016 01:38 PM
drobinson784
Jul 15, 2013 04:23 PM
ghostflamed
Jun 7, 2009 11:54 AM
