Screaming eagle Race tuner kit help
Old May 26, 2014 | 06:23 PM
adelii's Avatar
adelii
Default Screaming eagle Race tuner kit help
So I was looking over the stuff that the last owner had in a box he gave me and came up with a SERT part # 32107-01e
Im sure it is already installed, The guy i bought it from didn't know much about bike, and frankly neither do I. I have the whole kit. Bike runs well, just wonder if there is anything i need to know or do. Or something I can do later with this kit.
any help is appreciated.
Here is a pic of what i have
My bike is a 2006 electra glide ultra with vance and hines slip ons and looks like k&n type air filter.
Old May 26, 2014 | 07:29 PM
dawg's Avatar
dawg
You can hook up the tuner to the bike and a computer and it will tell you the map that is in it. If you mod the bike further you can tune the bike further. Can also send your tuner into TTS and Steve will upgrade it to the TTS Mastertune which is much better IMO. I sent my SE in to get the TTS.
Old May 26, 2014 | 07:54 PM
SafetyMan's Avatar
SafetyMan
Originally Posted by adelii
My bike is a 2006 electra glide ultra with acne....
I would try Clearasil.
Old May 27, 2014 | 01:25 AM
ke5rbd's Avatar
ke5rbd
TTS no longer does the upgrade. You can still buy the USB to serial adapter from them to be able to hook up to modern computers. The serial port is missing on newer computers. If you have old computer with serial you can hook up. Next problem software, unless you can find a cd and load it you may have rough time getting the software. HD quite making these about 2007. Looked at the photo again and see you have the CD.
Old May 27, 2014 | 05:38 AM
Gunnysgt's Avatar
Gunnysgt
The box probably contains your VCI. You need that in order to change anything on your ECM. The VCI box is linked to your bike's VIN so it's good he included that or you would have a real issue changing anything there. The VCI allows you or the dyno operator to communicate with your ECM.
Old May 30, 2014 | 02:28 AM
adelii's Avatar
adelii
Would i be able to take the vci to the dealer and have them upgrade the map? i am changing exhaust.
Old May 30, 2014 | 04:18 AM
Rustrtal's Avatar
Rustrtal
That should be a safe assumption.
.Sonny.
11
Jul 2, 2019 05:32 PM
Riven02
Aug 26, 2012 09:57 AM
bpop
Nov 7, 2011 02:43 PM
toez71
13
Sep 1, 2011 05:29 PM
gforce29
Jun 16, 2011 08:47 PM
