Need help .... Clutch issue
Old May 27, 2014 | 07:08 AM
Pyrotag's Avatar
Pyrotag
Default Need help .... Clutch issue
I upgraded the levers on my 2012 street glide and now I can't start the bike when it's in gear and the clutch lever is pulled in.
Old May 27, 2014 | 07:15 AM
Noble Jim's Avatar
Noble Jim
Adjust your clutch per the shop manual.
Old May 27, 2014 | 07:16 AM
hover's Avatar
hover
Sounds like you need to do a clutch adjustment. Read the manual and do the procedure that involves removing the primary inspection cover.
Old May 27, 2014 | 07:18 AM
Turret_plug's Avatar
Turret_plug
Not to insult you, but you reduced the cable slack, correct? 1/16" play in the cable ferrule at the lever perch? I'm curious if you pinched a wire from the housings somehow while you replaced the levers (if in fact you opened the housings installing them). I replaced a brake lever once (dropped bike and broke it) spent days trying to figure out why it wouldn't run, only to find out I pinched and shorted a wire in the right side control housing.
Old May 27, 2014 | 04:32 PM
Pyrotag's Avatar
Pyrotag
Thank you for the responses and help.
Old May 27, 2014 | 06:14 PM
RIDERED67's Avatar
RIDERED67
It is good practice to have the bike in neutral when starting. Especially with a cold engine. Adjust your clutch cable to fix your problem
Old May 27, 2014 | 07:05 PM
rickb's Avatar
rickb
There is also a video on you tube on how to do it. I like to refresh myself every now and again. Suks getting old.
Old May 27, 2014 | 08:50 PM
fat daddy's Avatar
fat daddy
Adjusting your clutch is not the problem,you have a safety switch that's suppose to be depressed when you pull the lever in and your not getting it pushed in. You'll have to add some material to your lever. Look inside the housing and you will see it.
Old May 27, 2014 | 08:53 PM
QC's Avatar
QC
Obviously, I'm not a touring rider, but when did Harley put this "feature" on bikes, and when did they do it? Was it done to all bikes after a certain year? I see this issue relatively often in here.
Old May 27, 2014 | 09:01 PM
07RoadHawg's Avatar
07RoadHawg
Exactly right about the clutch safety switch not being activated with the new levers.
'07 was the first year for the touring bikes, but the police models had it before then. Not sure the first year for them.
