Reusable air cleaner
Old May 29, 2014 | 06:17 PM
J2X's Avatar
J2X
Default Reusable air cleaner
Are the Stage 1 air cleaners reusable?
Old May 29, 2014 | 06:19 PM
gnewman's Avatar
gnewman
Most of them use K&N so you just clean them and reoil them.
Old May 29, 2014 | 06:20 PM
300Slim's Avatar
300Slim
Tech guy at the HD dealership said wash with dish soap and water.
Old May 29, 2014 | 06:23 PM
J2X's Avatar
J2X
Thanks, gentlemen. Will do. Have a good weekend.
Old May 29, 2014 | 07:07 PM
mkguitar's Avatar
mkguitar
depends which specific filter you have.
if a HD kit, ask at the dealer.
K&N are washable and need to be re-oiled.
The older ness ( and screaming eagle) used K&N.
Newer ness use an oiled washable filter similar to the K&N
mike
Old May 30, 2014 | 06:19 AM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
K&N makes their own detergent/cleaning/re-oiling kit to wash their filters. You can pick it up at any auto parts store. Some stage 1 filters are not from K&N though.
Old Jun 24, 2014 | 08:39 PM
Joe12RK's Avatar
Joe12RK
How do you know if K&N made the air filter? My SE filter looks it, but the K&N cleaning kit says it could dissolve other brands, so I want to be sure.
upon further review, mine says "dry filter do not oil" in fine print so I guess it's not a K&N. I did find the K&N filter element, Harley p/n 29400019 is cheaper thru surdyke than the K&N p/n HD-0818!
Old Jun 24, 2014 | 09:21 PM
mkguitar's Avatar
mkguitar
Originally Posted by mkguitar
depends which specific filter you have....
if a HD kit, ask at the dealer...
...older...screaming eagle...used K&N.
miike
Old Jun 24, 2014 | 10:23 PM
av ultra's Avatar
av ultra
If you have a k&n style air filter it will have a steel mesh with red or blue cloth in between the mesh, you can clean them with k&n filter cleaner and do NOT skip reoiling them before you put it back together, in the last couple of months I've seen a couple of filters that people cleaned and did not reoil.
Old Jun 25, 2014 | 09:43 AM
MadIrish's Avatar
MadIrish
My Kuryakyn AC uses a K&N
The filter is labeled with both K&N and Kuryakyn on the rubber on the downstream side of the filter. I imagine if you had a K&N, yours would be labeled, too.
