Engine Temp?
Old May 30, 2014 | 11:42 PM
mgmmgm's Avatar
mgmmgm
Question Engine Temp?
I did a search before posting- probably is info someplace,just did not get it.
I was riding today for about an couple of hours, open roads mostly 55-75 mph
and my engine temp on the PV was 240 - 250 range, crept to 260 while waiting at a lights once i got back in town riding in 25-35 mph traffic.
Sunny and high 70's today. I think the 250 temp is sort of high, is it?
I had my bike dyno tuned last Summer and I did not get the AFR reading with the sheet, my mpg 45.5 freeway for 73 mph, and 47-48 mpg at 55mph -60 mph highway riding.
I e-mailed the shop where I had the dyno tune performed to see if they saved a record of the tune, perhaps the AFR will show a possible lean condition? I get no ping. I do notice right thigh feels some engine heat.
I changed the oil last Sept, ( 3000 mile intervals & I use the scavenger method) , the oil is not even dark, and i have about 1000 miles to go but will change ASAP so, i do not think oil is broke down to not provide its ability to lube and cool the engine.
What is the normal range for engine temperature in 70-80 degree weather?
Thanks.
Old May 30, 2014 | 11:54 PM
user 8373900's Avatar
user 8373900
Considering 185-200 is operating temp for water cooled 250 270 doesn't seem out of line for air cooled. These Harleys are way hotter than that in stock form. Sounds like you can forget about the tuning now and just ride.
Mark
Old May 30, 2014 | 11:58 PM
Bagger_Vance's Avatar
Bagger_Vance
260 is not hot at all. You're fine.
Old May 31, 2014 | 12:04 AM
mgmmgm's Avatar
mgmmgm
i didn't have the ability to monitor the temps before the PV ...... ought to change the gauges to indicate something else, like front and rear AFR's!
Old May 31, 2014 | 12:07 AM
1Canuck's Avatar
1Canuck
If the dyno tuner used the PV to tune then the map is saved in the PV.
250-260 head temp is average from what I have read.
In another recent thread the PV displays three temps. 1-head, 2 engine 3-intake air.
The temp of 250 you are seeing should be headT which is the sensor at back of front cylinder. engine temp display is a calculation of the sensors to estimate overall temp and was shown higher. EIMTS kicks in around 280 abut the temp could go higher
your mpg does suggest a lean tune as most post an average of 40 mpg
Old May 31, 2014 | 12:22 AM
mgmmgm's Avatar
mgmmgm
1Canuck- "headT which is the sensor at back of front cylinder. engine temp display is a calculation of the sensors to estimate overall temp and was shown higher."
Okay, thanks. I will check the gauge to see if it is headT.
I do have the tuned saved in the PV.... i suppose I can monitor AFR's front and rear and see what that is in real time.
I did want the printed hard copy of the AFR's on the dyno sheet. ( dyno sheet is in my albums )
Old May 31, 2014 | 12:27 AM
1Canuck's Avatar
1Canuck
OK, I suspect your a noob with the PV. research power vision, download the software onto your laptop, get the cable to plug into PV to puter and you can open the map, print the tables yourself
Old May 31, 2014 | 12:59 AM
WARDSPARTSWERKS's Avatar
WARDSPARTSWERKS
Disregard the "HeadT" for temperature monitoring purposes, ET is the front cylinder head temp, it is much more stable and accurate. This is the feedback I got from Pat at DynoJet, still waiting a more in depth answer on the "HeadT" from the engineers. HeadT is an ECM logarithm value derived from several inputs, its not a real measured value. This new HeadT value is an excellent source of confusion to an already misunderstood topic, eventually I will get a real answer but in the interim I recommend monitoring ET for an accurate front head temp. BTW 240-260 is not anything to be alarmed about.
Old May 31, 2014 | 01:17 AM
1Canuck's Avatar
1Canuck
Originally Posted by fuelmoto View Post
...................... The second channel is Head Temperature which this is a bit more complex, it is a model the ECM calculates based on the ET sensor, the intake air temp (IAT) and other factors. Head Temp is used within the ECM primarily for Spark Temp correction, for most combination it will run between 260-400F. Note: Heat Temp has been recently added to the PV channel list an is reported as HeadT. The last channel is Coolant Temp which is active on twin cooled and V Rod applications. Hope this info helps...
right you are, had it backwards
Old May 31, 2014 | 04:40 AM
gnewman's Avatar
gnewman
My PV is reading around 250 also. Intake at around 140-ish.
