Back from the dyno
Old Jun 3, 2014 | 01:09 PM
'05Train's Avatar
'05Train
Originally Posted by wurk_truk
It actually depends on what kind of pop, and make the 'fix' match the pop.
If it pops right when the throttle is closed? Use DE. Also can do what Train is doing, with a PV.... if the pop isn't fixed by DE alone.
Now... long decel pop is different. Say you rev to 4k and close the throttle, then you get sporatic pop between say 3k to 2k? DE won't fix this. Again, if you use PV or SEPST, take the lowest KPA region and add a little fuel to the AFR range. Take some experimenting. Add a tad bit of timing on top, and should get fixed.
Now... with a TTS, one adjusts long pops totally different. TTS has closed throttle spark. Using that table, jack the 3000 rpm range timing up to like 30-40*. That advanced of timing will suck the flame front back into the pipe. Keep under 1500 rpm matched to the main spark tables. I match 2000 rpms somewhat to match idle.
DE is instantaneous. It is not a fix for pops that occur more than a second or two. Timing and fuel will need to be messed with.
Dirty Air? Once you use any tuner you will be out of EPA compliance anyways, so it becomes how well one wishes the bike to run as configured.
Train, depending upon how well low RPM VEs are fixed, you will STILL have a bit of AFV action, even in open loop, if the VEs are off a bit. To dirty air, how much fuel, when the throttle is closed, do you really think is used on a tenth of a Lambda point? Too small to measure at the exhaust for sure.
Point taken, and yeah, there's always DE to play with too.
BTW, the PV also has closed-throttle spark.
Old Jun 3, 2014 | 01:24 PM
FX4's Avatar
FX4
EPA compliance and smelling bad going down the road are two different things. Lots of bikes come off of dynos running dirty and you can smell them in a group ride. I do agree once you mess with a bikes tune it is no longer EPA compliant but that does not mean you are running dirty (fuel rich) either. And thank you I learned something new with this post about fixing decel pop. I guess what I have is a long pop as you call it. Letting off the throttle from high RPM and somewhere between 3 to 4k is when I will get a good pop.
Old Jun 3, 2014 | 04:00 PM
Bowhunter61's Avatar
Bowhunter61
Hey wurk, trying to learn all this stuff and do a lot of reading, the AFV action in open loop is only based on the AFV's learned in closed loop correct? So no new AFV's are populated but the sysem will still use the AFV's if necessary when in open loop. Do I have the correct?
So while in open loop I wont be gradually moving the VE's based on new AFV's being populated like I could be if I was running closed loop. Thought I read somewhere that when in closed loop the new calculated AFVs are saved off to the ECM when the bike is turned off.
harley2018
Milwaukee Eight (M8)
19
Dec 18, 2018 11:19 AM
chaselee
Jul 8, 2017 11:57 AM
Stricnine
The Dyno Room
Nov 4, 2016 07:06 PM
slowhand
Mar 4, 2011 03:30 PM
Angry_Inch
Jul 13, 2006 09:59 AM
