Yet another tuning question
Old Jun 4, 2014 | 05:45 PM
Bowhunter61's Avatar
Bowhunter61
Originally Posted by FX4
You can actually get mileage and performance. The settings become a little trickier with a lot of mountain riding because you are into the throttle a lot going up mountain passes so the trick is to set the performance part of the tune only where you really demand it. But if your riding calls for climbing a lot of steep grades mileage is going to suck no matter what. You have to give the thing gas.
That's not really what I am asking, I asking about air density/barometric pressure and the effect it has on the motor, not mountian riding.
From some quick research:
"Altitude decreases an engine’s octane requirements because of the change in air pressure. The higher elevations have a lower level of air pressure, which means an engine needs less octane to properly fire due to the lower ambient pressure. In certain states, such as Colorado where the altitude is generally above 5,000 feet in the mountain regions, 85 octane gasoline is sold, while in lower elevations 87 octane is the lowest sold.
When an engine requires lower levels of octane to “fire,” the overall efficiency of the engine is also lowered, which means the engine works harder to achieve the same results. However, less fuel burns, which means the overall fuel-per-mile efficiency is increased because the engine is working at a reduced compression rate. In short, you can get higher miles-per-gallon at higher elevations, but the power of the engine is also somewhat reduced."
So what I am asking is how does all this effect the tuning at places like Denver? If he tunes for Denver but then goes to Kansas and loses 4000 ft of altitude, what happens to his gas mileage and perfromance?
Also how do you compare that to like iClick who is most likely at sea level?
How does his mileage to performance hold up in the higher elevations?
Old Jun 4, 2014 | 06:27 PM
FX4's Avatar
FX4
It's a little bit of a complicated question. The way I have always understood things is oxygen density is what matters the most. The higher elevation the less oxygen. Less oxygen, less power, so more throttle to maintain speed.
Old Jun 4, 2014 | 06:34 PM
dschock's Avatar
dschock
Originally Posted by iclick
What tuner do you have installed now?
I have a SERT now so no real ability to view or change anything.
A head wind might explain the bad mileage at 80mph if you experienced it only once, but even then that would seem low. If the current tune takes a dive toward the rich for the KPA reading realized at 80mph this could happen. I've seen lots of tunes running closed-loop (14.4 - 14.6:1) up to 80 KPA, then 13.0:1 (open-loop) at 85 KPA, and that will make a big difference if you ride there often, as it isn't hard to move above 80 KPA in normal riding. Having a look at your AFR table would be helpful.
The PV would be a good recommendation, but be prepared to do some homework. There's a sticky thread for the PV in the tuner section of HDForums. There is the so-called AutoTune tuning method, which basically let's the PV do the datalogging and calculations with minimal user interaction, and a multi-step method of using WinPV and PVTune software (downloadable from the DJ site) for more selective tuning. I use the latter, as I like the control. There's no reason you can't tune for maximum mileage for your setup with little or no performance decrease, but if you have a mismatch somewhere (e.g., cam and pipes) you may never get it dialed in to your requirements.
What do you mean by mismatch? How would I know? I had an andrews 48H before the 57H and the head job. I was getting close to 50mpg on the interstate then. Don't ask me why I changed. Right now I'm wishing I hadn't.
FWIW, I just helped a guy with a 103 w/57H cams installed and he is only getting 25mpg, so you're doing much better than he is. He has mismatched parts and we're working on a fix now, although I'm not a hardware matchmaker, so I can only help him with the tuning.
I've rebuilt a few engines in my younger days so these concepts are not completely foreign to me. If I had confidence in a good tuner with a dyno, I'd probably go that route. However, I do like problem solving would like to better understand how tuning works. That's part of my interest in Power Vision and taking a whack at this myself. I'm not saying I could do better than an experienced tuner but I may be able to do better than some and get a better understanding in the process.
Old Jun 4, 2014 | 06:39 PM
dschock's Avatar
dschock
I'm 49 MPG though the mountains averaging 75MPH here in Pa. I did my own tune. I want to stress I did not auto tune. I spent a lot of time manually refining my tune with the Power Vision. It's nothing you can't learn but it does take time and a lot of reading.
I've read a number of your posts in different threads. Your views are one of the reasons I may give tuning a try. I seems auto tune pro with wide band sensors would help and maybe expedite the process of getting a tune I might be happy with. Do you agree?
Old Jun 4, 2014 | 06:43 PM
dschock's Avatar
dschock
Originally Posted by Bowhunter61
LOL...hell that is more than flat, can't you actually coast from Denver all the thru Kansas
Now that you mention it. I wonder if I actually had it in gear. That would explain the good gas mileage. LOL.
Old Jun 4, 2014 | 06:45 PM
FX4's Avatar
FX4
I would agree, but your timing curve will be very conservative.
Old Jun 4, 2014 | 06:55 PM
dschock's Avatar
dschock
Good questions and observations. I think my main point of comparison (un scientific) will be against the performance I've observed in the past. I had an andrews 48h before the head job and 57H. I was getting good mileage and power then. I'm getting good power now but the power curve is farther to the right as expected with the 57H. I wasn't noticing exceptionally poor mileage until after this last tune (last fall). This is the most riding I've done with it since then. The last time it was tuned they replaced the injectors (don't know if that matters).
Old Jun 4, 2014 | 08:20 PM
sporacer's Avatar
sporacer
I recently built a tman 107 for a customer. He got between 47-52 mpg in touring mode on the highway70-80 mph traveling from Connecticut to key west Florida. He was consistently .5 to 1.2 gals less fuel than a stock 110. The owner always has been a fuel miser compared to my driving style.
The build can be seen here and its tuned with a tts making 131.5 hp.
https://www.hdforums.com/forum/touri...107-build.html
HDSAE60
Aug 16, 2017 07:51 AM
LowRider68
General Topics/Tech Tips
May 31, 2015 09:56 PM
dschock
Jun 11, 2014 08:22 PM
Newharleylover
Jan 4, 2012 08:26 AM
DamnYankee
Sep 27, 2009 12:13 PM
