With the 103 we have little issue fully loaded, two-up.
FALSE. Absolutely, totally false.
Cams make more power provided the heads allow it and stock heads are not maxed out with stock cams.
I was waiting for this ;-) Cams shape available power. Heads make power. Compression makes power. Exhaust makes power, as well as a bunch of other stuff. I had a really educational discussion with the guy that did my head work, also one of the top engine builders in the area. He was very firm on this, cams do not make power they push the power band around one way or the other. Some cams perform down at low for torque and others at high RPM. The reason he likes the 204s for heavy touring bikes is because they have a broad flat power band with a lot of torque. He then took me to his dyno and pulled up dyno sheet after dyno sheet and showed me tunes with various cams and showed how the total output never changes just moves the available power around. The guy knows what he is doing. I am just a backyard mechanic, admittedly one that has built a lot of engines over the years but certainly I am not knowledgeable enough to challenge a proven engine builder that makes money off of engines he builds winning races. He also said he only uses Harley cams. They put way more R&D into cam profiles than any after market company has the financial resources to accomplish. Then he started in on bit of a rant about why he did not like various after market cams. I took this part of the discussion with a grain of salt. I have been around long enough to know every engine builder has their preferences and reasons why.
As side note: Very cool shop, all kinds of cool stuff hanging from the ceiling, old dragsters, race cars, and the back room had several drag bikes sitting on display. In addition to his engine building business he also drag races Harleys or at least used to. I'm not certain if he is still an active racer.
I am running the 48 in my 2012 Fugly ultra. Very happy so far, it does run a little on the warm side. I just removed the sliding door on my lowers to get some more air flow. Here is the dyno run.
It is my understanding that Harley has put the 255 in the new 103's. I am running the 255's in my 08 and my buddy is running the 254e's in his 103 11' dyno tune on both he is running the screaming eagle race tuner and i am running the power commander. very happy with performance.
My understanding is it is a similar cam profile but not identical.
Isn't the 254E just updated version of the 255s? I thought the 254E cams are a little easier starting but shift the start of the power band a few hundred RPM to the right and roll off a little later than the 255s. Guys that have ridden both say that can't really tell much of a difference between the cams.
The 2014's do NOT have the s/e 255 cams. Some of the specs are close but not the 255..
So by your statement above a stage 1 (fueling box/high flow ac/exhaust) would produce the same maximum HP/Torque as the stage 2? (stage 1 with cams added). I'm going to need to see dyno sheets to believe that. Different cams do move the power band left or right without question though.
No I am not saying this at all. The stock cams for the most part making power in one place or another is not the top priority. It's meeting emissions standards, smooth power band, and a bunch of other stuff comes before performance. A lot of energy from the stock cams leaves your motor as heat and they are intentionally performance restricted for various reasons. Emissions being the primary reason, but other things play into the stock cam profile like smooth power band, easy starting, and on and on. A cam upgrade in one form or another will increase your motors output but it's not making power, it's just releasing the motor's potential power. Performance cams attempt to maximize that power and put it where needed.
I had the andrews 48 on my 2012 FLHX 103. I loved it. Good low end torque. I later switched to the andrews 57H. That cam is good as well but the power curve is further to the right which means the torque is at a higher RPM. I may go back to the 48H.
