Caming The 103
1st - SE stage 1 air intake, D&D Fat cat, and SE 255 cam
Tune - map from Fuel Moto
Lot more take off power. Low end TQ improvement, and bike would run strong through the mids..... I was very happy - at first..... Started wanting more, and put in a 777 woods cam
2nd - SE heavy breather, D&D fat cat, woods 777
Map from FM,
Still bolt in cam - did not change springs or anything.... Changed lifters cause everyone's advise was Mexico lifters aren't good lifters......
WOW!!! What a difference!!!! I honestly feel like I got as much low end as before, maybe more, maybe not - but at least the same.....
BUt, way more power mid range and top end!!!!!!
These are butt dyno results. I have put two dyno sheets on this post. A base dyno run HD ran with my 255s, and a dyno on the 777s from FM website...
I also made a comparison chart while I was making my decision....
Just my $.02
I have the 777 and I hate it. Too much of a loss on the low end for my taste. Im switching to woods 222 here shortly because i barely ever go over 3500..which is just the spot to where those 777s start to wake up.
Im not trying to hotrod or do bagger wheelies I just want functional pulling power when Im riding alone or with a passenger... oh and I want a functional 6th gear.
My bike is currently in the who doing the stage 3 SE Kit.
SE big bore 10.5.1 Pistons
SE259e Cams
SE High Compress Value Springs
SE Perfect Fit Push Rods
SE Super Tuner
Installed Equip
MGS True Duals Loud Baffle
RSD Turbine A/C
Ill keep you posted with the numbers but Im sure I will be happy.
