oil leak
Old Jun 9, 2014 | 01:41 PM
xdanman's Avatar
xdanman
Default oil leak
I seem to have had a pesky little oil leak for a while now. I have cahnged fluids, using new O rings every time and torquing to specs. Still had just a drop every so often in my garage or at work. Had even taken to the dealer when it was still under warranty and they changed a gasket on something on front of motor. Still got drip!
A fellow rider at work told me that his oil pan was loose, so I thought I would check it. I had a couple of bolts not to tight at all. Pulled each on out, put some blue loctite on each one, and torqued them by manual, Bammm! no leak.
Old Jun 9, 2014 | 02:51 PM
danzio's Avatar
danzio
A trick I learned here on this forum is to sprinkle baby powder in any area where you suspect the leak may be occurring. I just tracked down a recent leak and found it to be at the stator plug and even though there was nothing wrong with the stator, I had to replace it due to this leak at the seal where the plug exits the primary housing. $250 dollars to replace a perfectly functioning part. Anyway the baby powder trick works pretty well, it will show a wet spot at the leak pretty quickly.
Good luck finding it. That's half the battle.
I guess I didn't finish reading your post. You found and fixed the problem. Good for you.
Old Jun 9, 2014 | 04:58 PM
mkguitar's Avatar
mkguitar
Originally Posted by danzio
A trick I learned here on this forum is to sprinkle baby powder in any area ....
spray on foot powder- 99˘ store
mike
Old Jun 9, 2014 | 05:12 PM
hdbob2006's Avatar
hdbob2006
I had the same problem on my '06. When I changed exhaust,I noticed there were a couple bolts on the pan that I could've spun out with my fingers!
Old Jun 9, 2014 | 05:44 PM
jdvorchak's Avatar
jdvorchak
Sorry to tell you about that stator. My buddy fixed his stator wire leak with $3 worth of black RTV. Cleaned up the area with brake cleaner, then used a screwdriver to poke RTV all around and under that "grommet". Been leak free for a couple of years now.
bparsel
EVO
27
May 6, 2021 06:01 AM
Dirt Bagger
Nov 19, 2013 10:05 AM
patharley
Jun 3, 2012 09:03 PM
87HDFXSTC
EVO
11
Oct 16, 2009 05:26 PM
ninetyfivebravo
Sep 10, 2008 09:35 AM
