Front cylinder noise -
Old Jun 11, 2014 | 08:06 PM
davessworks's Avatar
davessworks
Default Front cylinder noise -
Just riding home today (2010 Limited) - turned up the hill toward my house and there was an ungodly racket from the engine. Got it home and found it happens in the higher rpm range. Used mechanics stethoscope to determine front cylinder banging noise.
Leaky lifter? Any other ideas? Bike runs normally otherwise.
Old Jun 11, 2014 | 08:11 PM
steelerdude1's Avatar
steelerdude1
Just had the same thing happen to me, sounded like top end clanking, ended up being a loose compensator nut.
Old Jun 11, 2014 | 08:15 PM
davessworks
Hmmm - doubt it's a compensator nut - kinda wish it was. Worth a look. No noise from rear cylinder, plenty from front. Right side, not left.
Old Jun 12, 2014 | 06:18 AM
steelerdude1
When I asked about my noise here on the forum, it was suggested to check the lifters and inner cam bearings.
Good luck, the noise had me pretty freaked out, I though I had major problems. It is amazing to me how sound travels. I swore my clanking was coming from the top end, but the sound did seem to come from the left side, which makes sense since that's where the comp is.
Old Jun 12, 2014 | 07:16 AM
mrfikser's Avatar
mrfikser
you might want to check the front top engine mount, they come loose sometimes
Old Jun 12, 2014 | 07:35 AM
hardheaded's Avatar
hardheaded
check your front motor mounts if it's a knocking noise. could be loose compensator too! does it do it all the time or just when you rev it up ? heat shields, exhaust pipe and it could be cam bearings or lifters. start with the easy stuff first.
Old Jun 15, 2014 | 08:26 PM
davessworks
Thanks guys - I'll look into it. Lifters, valves, valve springs - all seem possible. I tightened down the exhaust a little - it seemed slightly lose - but not enough and the spec on that is pretty low if I recall.
Old Jun 15, 2014 | 08:37 PM
TUCCI's Avatar
TUCCI
Welcome to the noise chase group, many including myself, after awhile put ear buds and music in and just ride. If the motor grenades that's what I've got the ESP for.
Old Jun 15, 2014 | 08:59 PM
2AMGuy's Avatar
2AMGuy
Community Influencer
Count me in the club.
I'm taking my '13 CVO Ultra into the shop tomorrow morning for the 10,000 mile service AND to have them "listen" to a sound in my engine that I don't believe to be a normal engine sound.
At 2800 RPM's, under low-to-moderate acceleration I get a sound similar to "lifter rattle". It goes away at 3000 RMS's (or so) and once, when the engine was really warm (in mountain driving) the sound continued until I shut the engine off when we reached our motel.
Next morning....the engine returned to normal.
I'm hoping that they can find "something" that we can get fixed so I won't have to worry about the darned thing.
Old Jun 15, 2014 | 09:09 PM
user 8373900's Avatar
user 8373900
Rest easy, almost every stock twin cam I've ridden has that rattle mid 2-3 then goes away. Mine did too until I did cams and gave the pushrods a 1/4 turn extra.
Mark
