Cams installed backwards?!?!
Old Jun 15, 2014 | 08:56 AM
AnaChris's Avatar
AnaChris
Default Cams installed backwards?!?!
i recently had a new S&S flywheel, camplate, oil pump, hydrolic tensionrrs bearings, heads ...the whole shabang done on my 03 roadking flhrci. it was done by a very reputable shop who has done bottoms for me before and never had a hiccup....here is the thing. Im assembling this thing and trying to find TDC on compression to finish the rocker installation when low and behold i find that the compression stroke is on the exhaust side...of both cylinders. please watch the video. would swapping front for rear cams cause this? i need to take the cam plate out i think.
thanks in advance for your time and attention
Chris
having an issue with the video upload but will get it solved shortly.
Old Jun 15, 2014 | 09:03 AM
AnaChris's Avatar
AnaChris
https://www.facebook.com/photo.php?v...36007995018171
Old Jun 15, 2014 | 09:12 AM
H2OFOOTER's Avatar
H2OFOOTER
Ether you are rotating the engine backwards or you the push rods in the wrong holes. Cant install the cams backwards.
Old Jun 15, 2014 | 09:16 AM
AnaChris's Avatar
AnaChris
ah ****!...back to the FSM i read it wrong! i was rotating clockwise looking at the primariy shaft end....oopps. lets try this again. thanks for the help. Maybe i should call Capt. Obvious to look over my shoulder and save me from myself. ONWARD!!! my father's day present is a running Road King
Old Jun 15, 2014 | 10:25 AM
FX4's Avatar
FX4
Man I hate when that happens. Hello captain obvious! Been there more times than I care to admit.
Old Jun 15, 2014 | 10:37 AM
hdbob2006's Avatar
hdbob2006
Let's hope the starter knows which way to turn when you try to fire it up!! Similar thing I did: Took a starter motor off my boat motor,because the bendix wouldn't slide up and engage the ring gear. Cleaned,checked,polished,put it all back together,same problem. -Battery cables were on backwards,starter was spinning the wrong direction.
kryingame
May 7, 2016 02:53 PM
dbuzzell
Dec 24, 2015 07:54 PM
03dragonRK
Engine Mechanical Topics
Apr 27, 2015 06:29 AM
genshovel
Jun 15, 2011 10:05 PM
jsbridgew
May 17, 2008 03:42 PM
