CV Carb problem
Old Jun 16, 2014 | 02:53 PM
TomWoodgeard's Avatar
TomWoodgeard
Default CV Carb problem
I am working on my friends Sportster that has the CV carb. Yes, I know this is the Touring Forum, but I am hoping someone has had this problem. (Tried the Sportster forum and got a few replies.
With the air cleaner off and keeping the engine at 1500 - 1800 rpm's, I have a VERY small stream of gas coming from the accelerator pump discharge nozzle.
The bike is running very rich, and has fouled the front cylinder plug.
It will seem fine, then I shut the bike off, restart in a minute and it will barley start. I have to hold the throttle nearly wide open to get it to start. Lots of black smoke.
Has anybody had this problem and discovered a fix.
BTW, I installed a new vacuum piston and Float and needle. Set the float at .450 and also set it at .480. Neither setting had much effect on the richness.
Installed the '88 sportster needle and 46 pilot a couple of years ago and the bike has run perfectly since.....Except just now.......
Old Jun 16, 2014 | 03:03 PM
mkguitar's Avatar
mkguitar
guessing the ethanol has eaten the accel pump diaphragm, there should not be fuel coming from there unless the pump is activated by the pushrod on the diaphragm
replace it, 3 screws, carb stays in place.
i can;t remember the float setting off the top of my head...I know the measurement i used was in MM( added spec in post below)
check that the idle adjustment needle hasn't fallen out- locktite it.
for my 80" bikes with modified slides and sportster N65 needle I was usually using a .42 or .45 low speed jet, and a .175 high speed- that with a modified slide ( .125" hole, chamfered leading edge.)
nightrider.com has good modding and tuning info in the biketech section
I love the CV
mike
Old Jun 16, 2014 | 03:28 PM
DDuess's Avatar
DDuess
Seems like there is a ball check in there to prevent this, may be stuck with dirt/corrosion. Sounds like time for a clean and inspect on accel pump. Had start is due to rich mixture on a hot restart. Probably starts right up when cold right?
Old Jun 16, 2014 | 06:01 PM
TomWoodgeard
Starts right up when cold, but......Not much enrichener is needed.
I will put a vacuum test on the petcock to see if it's putting fuel in the vacuum line tomorrow.
Old Jun 16, 2014 | 06:10 PM
mkguitar's Avatar
mkguitar
Originally Posted by TomWoodgeard
I will put a vacuum test on the petcock...
ok, but your accel pump appears to be leaking into the carb... did you look at that?
mike
Old Jun 16, 2014 | 06:41 PM
TomWoodgeard
Replaced accelerator pump diaphragm today. Checked jet tightness, Will reinstall carb tomorrow after checking petcock.
Old Jun 16, 2014 | 06:58 PM
mkguitar's Avatar
mkguitar
float setting per 1990 manual is
.725~.730" or 18.4~18.5 mm
from flange face to float perimeter with carb inverted.
bend tab to adjust
4mm allen heads are a good replacement for the float bowl screws since you have it off.
makes for tuning roadside easier.
mike
Old Jun 17, 2014 | 01:56 PM
TomWoodgeard
Ok....Tested the petcock using my mighty vac - Gas comes out of the vacuum hose.
Naturally, both dealers do not have the petcock in stock - ordered - At least 4 days to wait.
I will reply in 4 or 5 days with the results.
Thanks for all the help and ideas.
Old Jun 17, 2014 | 02:02 PM
mkguitar's Avatar
mkguitar
you might consider replacing with a non vacuum petcock.
as owners are discovering, alot of the rubber parts on our bikes do not hold up to the additives packages in pump gas.
which is the end results in increased emissions from raw gas spills or over rich mixtures.
mike
Old Jun 17, 2014 | 02:07 PM
TomWoodgeard
Also.......According to H-D factory shop manual for 2006 XL, the float height is supposed to be .413 to .453 (When tilting the carb 15 - 20 degrees)
diddlyd
Carburetor Related
Dec 19, 2015 11:17 PM
CZshooter
Carburetor Related
Aug 5, 2015 09:15 PM
bigcountry4160
Carburetor Related
Apr 16, 2014 05:47 AM
PyroPornStar
Exhaust System Topics
Apr 21, 2013 06:57 AM
pleasants9
Jan 31, 2011 10:16 AM
