flash2pass problem
Old Jun 25, 2014 | 10:39 PM
kustom78's Avatar
kustom78
Default flash2pass problem
installed this system and it worked properly for a few weeks, then it started not closing the door from the button on the wall or from the car garage opener. when i push the button it will start down and at some point just stop and reopen then i have to hold the button till it closes. its getting really annoying! i bought a 9v 300mA charger and it made it worse. anyone else have an issue like this?
Old Jun 25, 2014 | 11:02 PM
LA VIC's Avatar
LA VIC
Never had a problem with mine, had it 2 years. I don't understand the 9v 300mA charger. What's that for?
Old Jun 26, 2014 | 10:25 AM
kustom78's Avatar
kustom78
some motors dont put out enough to power the reciever so theres a small round external plug in the bottom. just thought maybe that was my problem but its not. anyone with any input? the wifes getting irritated and either wants the old opener back on or this fixed.
Old Jun 26, 2014 | 10:48 AM
Koafarms's Avatar
Koafarms
Check your door springs and tension, sound like you might have one side that broke or is getting weak. Or your safety light along the bottom got bumped or needs cleaned.
Old Jun 26, 2014 | 05:38 PM
LA VIC's Avatar
LA VIC
Have you disconnected the Flash 2 Pass and confirmed the garage opener goes back to working normally?
Old Jun 26, 2014 | 08:54 PM
Rdgray's Avatar
Rdgray
Get your manual, sounds like your down force needs to be adjusted. Only turn it about 1/4 of a turn at a time and try.
Old Jun 26, 2014 | 09:38 PM
Punjabi Rider's Avatar
Punjabi Rider
Have it for over 5 years on 2 bikes works flawlessly may be try reprogramming from step one and also like mentioned before the springs has to do a lot with opening and closing force.
Old Jun 27, 2014 | 07:28 AM
CGLTD's Avatar
CGLTD
And here I thought you added a button to flash you headlights to try and get people to move over so you can pass! BMW bikes have that. Of course that doesn't work in the US because everyone wants to drive in the left lane and not let people pass!
Old Jun 27, 2014 | 08:47 AM
Nute's Avatar
Nute
Mine worked great for over 2 years. Every spring I had to reset it and then a couple of times throughout the summer. I had big problems with it in the beginning and had to purchase the power supply which seemed to solve my problems. Last fall it stopped working altogether. Gave up on it altogether went back to the remote. Suspect the sending unit was NFG. Nice when it worked but couldn't rely on it.
Old Jun 28, 2014 | 10:29 AM
kustom78's Avatar
kustom78
thanks for the advice guys, i put the original wall unit back on and the problem was still there, looked at the sensors and found the wires barely twisted together. i cut the ends and jellybeaned them together and works great now!
SecondGear
2014-2024 Touring Models
13
Feb 28, 2018 12:48 PM
skibum0607
Mar 24, 2015 06:09 PM
Scorpio49
21
Jan 1, 2014 12:00 PM
Edywazoo
Jul 24, 2011 01:01 PM
roadgliderick
Oct 27, 2010 10:44 PM
