Brake Issues far from home.. HELP PLEASE!
Old Jul 7, 2014 | 06:33 AM
santajim's Avatar
santajim
Keep bleeding you still have air in the lines.
Old Jul 7, 2014 | 07:09 AM
fro10987's Avatar
fro10987
6th Gear
i would bleed again and also try to spin the front wheel and be sure you did not accidently bend the rotor when changing the tire
Old Jul 7, 2014 | 09:31 AM
SIDECAR BOB's Avatar
SIDECAR BOB
would be odd that it happened to both at the same time , but wondering if the master cylenders could be going out? if brake fluid types were mixed ( maybe from a previos repair, the wrong fluid was used)
Old Jul 7, 2014 | 09:38 AM
Trucky911's Avatar
Trucky911
"We did the brake line furthest from the master cylinder then on to the closest one with no air."
There is a master cylinder for each wheel. Not like a car w/ 1 master cylinder.....
Trucky911
Old Jul 7, 2014 | 10:15 AM
TWIN CAM 96's Avatar
TWIN CAM 96
Try one of these should be all you need to do + the right brake fluid for the application
Greenberg Brake Bleeding Method
Hydraulics Bleeding (Brake and Clutch)
Mityvac Vacuum Pump - Save on Mityvac Pumps at Harbor Freight!
Old Jul 7, 2014 | 10:27 AM
TUCCI's Avatar
TUCCI
Bike brakes are very easy to bleed so something along the process may have been done wrong. ABS is a little trickier but still fairly easy.
Old Jul 7, 2014 | 10:33 AM
porschemann's Avatar
porschemann
Originally Posted by SR90
Your first post indicated you had to pump the brakes for them to be firm, that would be air in the lines. Maybe the bleeder screws are allowing air back in. I put Teflon tape on mine, but I had the entire caliper off for a rebuild at the time. Otherwise, as Tim found, the pistons just aren't moving enough. The pistons in my rear caliper were so dirty they were jammed at an angle. Had to used pliers to remove them. Hence, new rebuild kit with pistons and seals. Been meaning to rebuild the fronts too, but I think they'll just need seals and a good flush.
NEVER put Teflon tape on bleeder fitting threads. There is a high risk of cracking the caliper housing as there is no room for a sealant on the threads. The nipples by the way to not seal at the threads. At the bottom of the nipple is a machined surface. It is what seats at the bottom of the bore and makes a seal. It is the same principle as AN fittings. It is a metal to metal seal. When the bleeder fitting is loosened, the fluid then comes up and enters the nipple through a hole on the side above the sealing surface. If you have a Bleeder fitting that weeps fluid, then it is because the seat inside is either dirty, corroded, or has been damaged from over tightening the fitting in the caliper.
The OP sounds as if two things are happening. 1) there is still air in the system, and 2) pistons are not moving freely.
Remove calipers, and clean around pistons with brake clean and an old tooth brush.
Old Jul 7, 2014 | 11:48 AM
Potato_Potato's Avatar
Potato_Potato
Good to know. I have never done it but read about people doing it here and thought of doing it.
Old Jul 7, 2014 | 01:38 PM
TWIN CAM 96
A shoestring with brake kleen may work also with no tear down involved just zip tie the front or rear lever down before cleaning to clean pistons (Keep spray away from painted surfaces)
Old Jul 7, 2014 | 04:11 PM
Tim_Sr's Avatar
Tim_Sr
Hey notdrphildrmike, did you ever try cleaning the calipers real good. if so what did you discover? Now ya got me curious as to what the problem was.
