screaming eagle throttle by wire upgrade?
Old Jul 8, 2014 | 03:12 PM
adamsrotors's Avatar
adamsrotors
Default screaming eagle throttle by wire upgrade?
doing a bar swap on my 2010 electra glide and my buddy installing recommends I upgrade the fly by wire to the SE one...says they can go out around 20k miles? also, now is the time to do it.
looked into it and it seems like maybe this is just to make it easier for the installation and not even needed?
1. is it worth upgrading? is the response & such actually noticable?
2. do the original ones fail? is it a known issue? bike as 25k miles and seems fine...tho who knows.
thanks for any input on this...
Old Jul 8, 2014 | 03:22 PM
prezflyr's Avatar
prezflyr
I still have the stock setup on my 09 Ultra with 55K miles and no problems----YET
Old Jul 8, 2014 | 03:24 PM
adamsrotors
^ but is it a thing?
anyone do the swap and think it's worth it? $125.
Old Jul 8, 2014 | 03:29 PM
TUCCI's Avatar
TUCCI
I had to replace mine when I damaged the original when I swapped bars but can't tell you if it's the SE version, hell I didn't know there was a newer version. I can tell you if they fail, the bike will start, the check engine code will show on your dash and you wont have diddly for a throttle. If the original is still usable put it back in is what I say.
Old Jul 8, 2014 | 03:30 PM
adamsrotors
I know...doing a budget build on this bike in general and trying to save where I can.
Old Jul 8, 2014 | 03:48 PM
SBates08's Avatar
SBates08
No they aren't known for failing on their own and you won't be able to tell the difference between the 2.
2010 Limited with some stuff
Old Jul 8, 2014 | 04:20 PM
09 YELLOWBIRD's Avatar
09 YELLOWBIRD
Is this something new?
As I have never heard of a SE TBW before!
Please do fill us in.
YB
Old Jul 8, 2014 | 04:27 PM
adamsrotors
^ I'm obviously not the one to ask, hence the post.
Old Jul 8, 2014 | 04:36 PM
Jags93's Avatar
Jags93
I think the only difference is the wire. The wire is longer so there is no connector in the handlebar. Don't some of the SE bikes have internally wired bars? I think that's the only reason.
Old Jul 8, 2014 | 04:47 PM
SBates08's Avatar
SBates08
Yep only difference is no green plug and a longer wiring harness.
