Progressive Monotubes how many clips?
Old Jul 15, 2014 | 07:51 PM
Lucky1359's Avatar
Lucky1359
Default Progressive Monotubes how many clips?
I am going to put Progressive Suspensions Standard length monotube kit on my 04 Road King. I have done my research and read many of the reviews and help threads. But as I go over the directions it says to install 2 of the clips. However I have read about guys only installing 1. I am about 210 lbs ride solo just about all the time. So my question for you guys is do I install 1 or 2 of the clips?
Old Jul 15, 2014 | 08:31 PM
soberjoe's Avatar
soberjoe
It is a big job to install them so getting it right the first time would be great. My bike is torn down now and the monotubes will be here tomorrow. From all I've read, one clip is the ticket. I'm a bit over 200 lbs my self. My wife rides with me now and then. But I would like a softer ride, two clips is a bit stiffer. Good luck to us both.
Old Jul 15, 2014 | 08:41 PM
Keithhu's Avatar
Keithhu
I would call progressive. I'm 175, 1 clip is perfect for me, at 210 I'd think 2 clips.
Old Jul 16, 2014 | 06:08 AM
'05Train's Avatar
'05Train
It depends on what day you call Progressive. I was told two clips, other riders my size have called and been told 1 or 2. With 2 clips, the front end is lowered about 3/8", it'll drop about another 1/4" if you remove one of the clips.
Progressive sells junk, and my Monotubes were yanked out after about 3,500 painful miles. Aside from the fact that it's BS to advertise something as stock height that lowers your bike, they just didn't work. That their customer support people don't have a clue how their products work is just icing on the cake.
Old Jul 16, 2014 | 07:01 AM
sanman4ever's Avatar
sanman4ever
Tell us how you really feel.......but your so right on all counts here.
Old Jul 16, 2014 | 07:56 AM
baddad13304's Avatar
baddad13304
I used 2 clips and I'm about 200lbs before a night of beer and chicken wings. Works well for me and I'm happy with the ride and handling over stock. Ride to me is firm not harsh with very little brake dive. I did not measure ride height prior but do suspect it lowered the bike somewhat because turn in is quicker. After about 300 miles the only problem I have are the 2 to 3 foot wide dips where the road was repaired or something. Those dips are a jolt and it seems that the forks take the initial hit fine but coming out don't respond quick enough.
Old Jul 16, 2014 | 08:29 AM
Hardcorvette's Avatar
Hardcorvette
I'm currently 210 lbs and have been running Progressive Monotubes for about 2-1/2 years. I removed the 2 shims a month ago to lower the front end. It does somewhat soften the firmness of the ride, but its not a major difference. I have over 6,000 miles with the Monotubes, no complaints at all. Definitely much better than the POS stock springs.
Old Jul 16, 2014 | 10:21 AM
Hotrodz_n_Harleyz's Avatar
Hotrodz_n_Harleyz
I went with one and I'm 245 and it's good for me. It will firm up the front end significantly. 05 train makes his opinion known about the monotubes every time a thread mentions them. I'm starting to get the impression he didn't care for them in his bike. There are many, many others however, that like them very much, including myself. your experience will be all that matters to you once you've ridden with them. I do agree with him however, that progressive should really make it perfectly clear that the monotubes will lower your front end to varying degrees depending on the clips you use before you buy them, because they most certainly do. Other than that, for me, they've been a very worthwhile upgrade to my road king.
Old Jul 16, 2014 | 04:00 PM
Lucky1359's Avatar
Lucky1359
Thanks for all the help and input guys! I am looking forward to getting these installed and seeing firsthand the difference. And yes I have seen just about all of 05 Trains comments and displeasure for the product and company on every thread I have read. I am not looking for this to turn into a plush ride. Its a motorcycle and the roads in PA suck, any little bit of difference in a positive manner is a plus in my book!
Old Jul 16, 2014 | 04:33 PM
'05Train's Avatar
'05Train
PA roads do suck. I rode to and from Iowa via the PA Turnpike outside of Pittsburgh. 76 is a disaster area through a lot of that area from Youngstown thru to Breezewood. Saying that the bike beat the hell out of me is an understatement. Between the lousy pavement and all the construction, I was fighting to keep the bike in its track within the lane. With two clips in (which is what Progressive says to use in their printed instructions and what I was told on the phone), there's almost no compliance in the front end whatsoever.....It rode like a rigid. In 38 years of riding all sorts of bikes on all sorts of surfaces, I've never been more uncomfortable than I was on that trip.
And yes, I know that there are plenty of people who are perfectly happy with their Monotubes. For the life of me I can't understand how, unless they're riding on glass-smooth roads. I've traveled all over this country, and I have yet to find those roads.
