Issues After Cam Change - Need Inputs
Old Jul 17, 2014 | 08:08 AM
Redbeard719's Avatar
Redbeard719
I've researched cam installations pretty extensively prior to doing any of my own. As you know, it's not an overly complicated job.
The one thing I found though was that most times when people had low/no oil pressure, it was due to a pinched O-ring on the oil pump where it mates into the engine case. Also, there are 2 other O-rings that are installed in the engine case and seal oil passages to the cam support plate.
Also, the O-rings in the cam chest should be replaced with new ones. Despite the old ones looking good and acceptable for reuse, they're not. Heat cycles and being compressed for so long a certain way means they're not able to get the initial seal needed when installing the parts.
I've never soaked or filled new lifters on my installs, but I have used plenty of assembly lube. After you start your bike, the lifters should pump up within 5-7 seconds and within 10 seconds your top end should be getting oil too to quiet the rocker assemblies. A minute without an increase in oil pressure is too long.
Old Jul 18, 2014 | 11:56 AM
Kokes58's Avatar
Kokes58
I found the reason for no oil pressure. I took everything back a part this morning and come to find out the internals of the oil pump are broke. I don't know what happen. I never took the oil pump off the cam plate. The O Ring was still in place. Guess it was just time for the oil pump to go. At least now I know.
Old Jul 18, 2014 | 01:16 PM
Notgrownup's Avatar
Notgrownup
Good for you, caught it before real damages...
Old Jul 18, 2014 | 01:27 PM
jammerx's Avatar
jammerx
Good deal, odd but now you know!
Old Jul 18, 2014 | 07:08 PM
2-Piece's Avatar
2-Piece
Did you at least loosen up the oil pump bolts when you re-installed the cam plate?
Part of the re-assembly process it to install the pump with the bolts loose and rotate the engine. This centers the pump on the crankshaft.
Old Jul 19, 2014 | 04:08 AM
Kiwirob's Avatar
Kiwirob
If the plate & the pump are removed as one, there is no need to re-align the pump upon re-assembly. Just need to be careful that "O" ring is in properly when pressing pump & plate into place. - Rob
Old Jul 19, 2014 | 05:41 AM
Tn.Heritage's Avatar
Tn.Heritage
What O ring are you referring too ? If your working on a 09 model there shouldn't be a O ring on the oil pump where it bolts to the cam plate. Also you may need to check your crank run out to see if that may be a problem as well.
Here's a picture of my oil pump from my 2010 and there's no O ring on the pump. Sorry if I'm going in the wrong direction here just trying to help.
Old Jul 19, 2014 | 06:08 AM
Greezey Rider's Avatar
Greezey Rider
Just go ride it for a few hours....If the oil pressure doesn't come up, head to the dealership and blame them for selling an inferior product.
Then come here and post a 30 paragraph rant about how poor the design is.
Old Jul 19, 2014 | 02:01 PM
Kiwirob's Avatar
Kiwirob
The one that goes between pump & crank case. - Rob
Old Jul 19, 2014 | 03:51 PM
Lowcountry Joe's Avatar
Lowcountry Joe
Just wondering how the internals all the sudden broke on the oil pump? That's odd.
