Lost throttle today
Old Jul 17, 2014 | 09:39 PM
skiddd's Avatar
skiddd
Default Lost throttle today
On the way home from a ride around 2 miles from my house I lost the throttle(I have a 2009 street glide) I managed to get home with it in idle, but did in fact have a tiny bit of throttle(going full on throttle it gave me about 300 rpm's) I got home and shut her down for a bit. when I started it back up I had throttle again...... no idea why, any clues? I didn't check the codes yet as I had a ton of **** to do...........
Old Jul 17, 2014 | 09:44 PM
dawg's Avatar
dawg
Check codes, clean the contacts on the plug behind air cleaner, may have to change the contacts too per the service bulletin.
Def Mute's Avatar
Def Mute
Over heating can cause the bike to limit rpms to 3000. After it cools down, should be good to go again. But, I would try to find out why it over heated...
Old Jul 17, 2014 | 11:41 PM
ownasofttail's Avatar
ownasofttail
Just had the same thing happen a couple weeks ago, The plug to the throttle body has pins that get messed up dealer has replacement pins that seem to fix this problem. Like $6.00 Good luck.
Old Jul 17, 2014 | 11:45 PM
skiddd's Avatar
skiddd
Cool, thanks for the reply's gentleman. I was a little taken back because the bike was not hot at all. I will check the connection in the morning....... Ride safe Men.
Old Jul 18, 2014 | 05:43 AM
Weavr99FLHT's Avatar
Weavr99FLHT
it's called Limp mode ... there should be code... you are not the first... probably nothing to do with overheating.
Old Jul 18, 2014 | 05:58 AM
skiddd's Avatar
skiddd
Thanks Man, gonna check the codes today sometime.........
Old Jul 18, 2014 | 07:41 AM
santajim's Avatar
santajim
Has happened to me twice first was TBW sensor in handlebars second was at the throttlebody dealer fixed problem both times.
Old Jul 18, 2014 | 10:46 AM
Bingee's Avatar
Bingee
Chances are you are having the problem described in HD's TT418A document. Do a google search on TT418A. Lots of posts in "hdforums" related to this problem and some fixes as well.
Old Jul 18, 2014 | 12:49 PM
skiddd's Avatar
skiddd
Thanks Man.........
