Cams
Old Jul 18, 2014 | 11:11 PM
06Cummins's Avatar
06Cummins
Default Cams
Going to be doing cam tensioners and wanted to change cams while I was in there.
I have a 2004 twin cam 88 and want to know what is the biggest cam I can run without having to any head work. I'm going to adjustable pushrods and aftermarket covers. New hydraulic tensioners and cam bearings.
Old Jul 19, 2014 | 06:12 AM
jus2anoyu's Avatar
jus2anoyu
Do you really want to run the biggest cams that will fit? Or what's best suited to your riding style?
Old Jul 19, 2014 | 06:18 AM
6 gun's Avatar
6 gun
I believe I would ask your question here
https://www.hdforums.com/forum/engin...cal-topics-46/
Old Jul 19, 2014 | 06:59 AM
kojak's Avatar
kojak
No reason to change cams unless you are doing performance engine work.
Old Jul 19, 2014 | 09:11 AM
simpkinst's Avatar
simpkinst
No idea what you mean by "biggest" cam, but the Andrews 21 is the best cam for an otherwise stock 88 in my opinion.
Really makes a big difference over stock.
Not sure what some are saying about not worth it.... Makes no sence to me.
Best money I have spent on my 88.
Old Jul 19, 2014 | 08:16 PM
fidel's Avatar
fidel
i run an andrews 26 when im at 88 i love it in my road king good upgrade now i run an andrews 57 in my 98 ci wuth ported head
Old Jul 19, 2014 | 08:56 PM
131IRONMIKE's Avatar
131IRONMIKE
That 26 will wake your buggy up,with a good tune....
Old Jul 19, 2014 | 09:03 PM
06Cummins's Avatar
06Cummins
Yeah I ride two up most of the time and long rides are single. Figured I might as well change them out while in there. And I do know motors and changing cams well make a difference even without other mods done to motor. I'm also going to have it dyno tuned after cam install.
Old Jul 19, 2014 | 09:32 PM
BackRoader's Avatar
BackRoader
I also do lots of 2 up riding. The Andrews 21 is a great cam for this. Gives you low end grunt and pulls as far as i care to push her. Some say the 26 is better, but it kicks in later in the rpm range. The 21 comes on at 1700 rpm, almost right off the line.
Old Jul 19, 2014 | 09:39 PM
mikelikesbikes's Avatar
mikelikesbikes
A year and a half ago I had Andrews 57H cams put in my 01 Road King with the intent of going to 95". Finally getting the 95 in after the trashed bike is rebuilt. I was quite happy with the 57's with the 88" but can't wait until the 95 wakes this thing up and anticipating being able to lift the front end up if I want to.
