95 Tour glide seat
Old Jul 20, 2014 | 12:06 PM
wesbk200's Avatar
wesbk200
Stage II
Default 95 Tour glide seat
I just bought my first Harley, a 1995 Tourglide Ultra Classic that has been slicked down to a Roadglide basically. It came with a Lepara silhouette solo seat and it's ok for about 30 minutes then it gets uncomfortable. I have looked for double seats for that model but the options are basically couch cushions and I'm looking for something a little more sleeker or sportier. Will later year model seats fit? I have a friend with a 2010 Streetglide that says his factory seat is super comfy and I like the way it looks. I know some fab work on the tank mount may be necessary and that's no problem
Old Jul 20, 2014 | 12:09 PM
mkguitar's Avatar
mkguitar
you may be able to fit an 2008 or earlier seat on your frame....but....
alot of the guys here use mean city cycles for seat work.
I have the same seat as your pal- I would say ( for me) good for up to 4 hours, painful at 6.
if you are touring you need a 'couch cushion for' 8 to 10 hour days.
Mike
Old Jul 20, 2014 | 12:14 PM
SafetyMan's Avatar
SafetyMan
Check the aftermarket.
Corbin
Mustang
Le Pera
Saddlemen
I don't think the 2010 stocker will fit, there is more to a seat fitting than the tank tab. The frame and fender must match also.
Old Jul 20, 2014 | 12:21 PM
SafetyMan's Avatar
SafetyMan
Here's a couple of quick search links:
http://www.corbin.com/harley/baggers/fltour.shtml
You can pick color, style, material, stitching....
http://www.mustangseats.com/Category/Sport-Touring
http://www.saddlemen.com/profiler-se...arley-davidson
http://www.lepera.com/seat_pgs/v3_Dresser_result.php
Old Jul 20, 2014 | 12:24 PM
grbrown's Avatar
grbrown
Your bike was introduced 20 years ago, so you are better off looking at the long established seat brands, such as those SafetyMan listed. If you see a style you like with one of them call to see if they can make one for your model.
Old Jul 20, 2014 | 01:31 PM
wesbk200's Avatar
wesbk200
Stage II
I'm not planning on doing any major touring. At most 2-3 hours at a time.
Old Jul 21, 2014 | 11:08 PM
gambler85gw's Avatar
gambler85gw
Default Newer seat on 96 ultra
I modified a later seat to fit my 96 ultra. You cut both sides of the pan starting about 4 in. back and 8 in. Long. Go from nothing to 3/4 in. To nothing for 8 in. The 3/4 at 4 in. front beginning of cut and about 8 in. from front of seat. Pull cover tight and re staple. Remove rear seat bracket. JB weld 2 1in. long bolts to match the holes in the fender bracket. I did not bend a frt seat bracket yet but seat fits great and looks great. I will make frt tank bracket later.
pablotheman
Apr 1, 2017 12:30 PM
Tnaski
13
Mar 5, 2013 07:00 PM
reefkeeper
Aug 21, 2011 10:34 AM
bennenrkc
May 10, 2010 06:44 PM
chopfury
Sep 15, 2009 01:49 PM
