Just Shooting An Idea Out There
Old Jul 20, 2014 | 12:41 PM
6 gun's Avatar
6 gun
Default Just Shooting An Idea Out There
I am getting sick and tired of my obnoxiously loud pipes, but I hate duels on my bike. I'm thinking about trying to find a cracked "Y" pipe and plugging up
the left side. I know from what I have read on here, that cracked y pipe were sorta common on the older touring bikes. So if you have done this, is it, or was it good idea? I have the stock exhaust system that came on my bike but I don't want to ruin it, with a "maybe." By doing this I would have a semi stock two into one H D exhaust with out cats if I used the left side muffler on the right side, or an SE slip on. What are your thoughts on this?
Old Jul 20, 2014 | 01:44 PM
mkguitar's Avatar
mkguitar
if you have the 09+ frame the old header won't clear.
a freeze plug like $3 at pepboys can be used to seal an exhaust crossover...even like on the 09+
in terms of flow- alot of the commercial 2/1's go to 2" which will flow much more than a 1.75"- how much more? --- about another 40%
mike
Old Jul 20, 2014 | 01:49 PM
TWIN CAM 96's Avatar
TWIN CAM 96
2 into 1 all the way Chop Chop!
Old Jul 20, 2014 | 02:18 PM
6 gun's Avatar
6 gun
Yeah that is what I'm thinking maybe i can just buy a
used "Y" pipe off of E-bay or something to chop and weld
Old Jul 20, 2014 | 02:42 PM
grbrown's Avatar
grbrown
Why not simply buy a proper 2-into-1 like my Supertrapp, below? Adjustable baffles, so you can tune the noise to your liking, plus the benefit of improved low/mid range torque and a sweeter running engine.
Old Jul 20, 2014 | 02:48 PM
lp's Avatar
lp
2010 RG or SG 2-1 headers are around and pretty cheap.
Just would have to remove the Cat if that's a problem for you. Wasn't for me.
lp
Old Jul 20, 2014 | 04:04 PM
6 gun's Avatar
6 gun
I don't know duels really aren't that bad looking I may just put my stock exhaust back on one of these days, but more than likely I'll just say screw it and do nothing.
Old Jul 21, 2014 | 08:24 AM
SPECIAL ED's Avatar
SPECIAL ED
Really not that bad of an idea. I picked one up in the classifieds for around 120 the full system with heat shields an everything.Then I had a muffler shop make me an extension so I could run one of my American Customs Bomber mufflers.I left the cat in and I can use the muffler with no baffle and it's still not even close to what I would call obnoxiously loud.Also since it's basically a stock system you don't need any kind of fancy tuner to get it to run right.
Old Jul 21, 2014 | 08:52 AM
'05Train's Avatar
'05Train
OP's got a 2007, so 2009+ anything isn't going to work without some fabrication.
Old Jul 21, 2014 | 09:47 AM
lp's Avatar
lp
The a stock HD 2-1 won't be any work.
Same engine and trans exhaust hanger configuration.
Shouldn't be anyway...
lp
