255 cam decision help\opinion
Old Jul 28, 2014 | 05:08 PM
  #41
BuzzL's Avatar
BuzzL
Originally Posted by Eshaw301
I wouldnt go so far as to call it obsolete. The 255 is a torque cam plain and simple. To this day, there is not a bolt in cam on the market that makes more torque at a lower rpm than the 255. If there is one, and its an apples to apples comparison (same motor, mods, etc.) I havent seen it. You ask any reputable engine builder, cam manufacturer, supplier, etc. and they will confirm this without a shadow of a doubt. From idle to 4000 rpm, the 255 cant be touched as a bolt in cam on a stock or stage I motor. There may be more choices, but none of them offer the low down torque that the 255 offers.
Well stated, I love mine
Old Jul 28, 2014 | 07:26 PM
  #42
rickb's Avatar
rickb
I just wonder about reliability of all these "over .550" lift cams on the valve springs and guides, in say 60k miles? I would stick with some thing around .500.
Old Jul 28, 2014 | 07:30 PM
  #43
bgdv1's Avatar
bgdv1
id go with the 254E cams
Old Jul 29, 2014 | 12:04 AM
  #44
ke5rbd's Avatar
ke5rbd
I am afraid I disagree with you on no bolt in cam will beat a 255 from idle to 4000. For one the 222 will beat it from 2200 on up for sure. Only time you are below 2000 is taking off anyway. Have seen several 255's in CVO's replaced with TW222 and no comparison anywhere. Seen a couple of 222's put in 103's with 255's that were installed by dealer when new as upgrade. No comparison. All these had tuners with the 255's except one of the CVO's. There are some others that will do it also and are bolt in cams. Andrews 48H comes to mind. I doubt very seriously Woods, Andrews, S&S and FM will confirm your statement. It may have been true few years ago, but not now. I am not saying they are obsolete, as they do still have their place as an epa compliant cam that runs well.
Old Jul 29, 2014 | 10:42 AM
  #45
Spider0408's Avatar
Spider0408
Originally Posted by dickey
I agree. I just installed the 254 cams & the difference is spectacular..has more midrange than the 255 & according to the SE catalog, will pull ahead of an identical 255 equipped bike.
Where in the catalog do you see this? The SE catalog clearly shows the exact opposite of what you said. Check the post by Bingee where the SE chart is.
Old Jul 29, 2014 | 11:57 AM
  #46
StevieRay59's Avatar
StevieRay59
What cam would you suggest for a 2014 FLHTK Limited with a stage one exhaust, air cleaner, Power vision tuner. I ride 2 up most of the time. I'm thinking a woods 222 cam? Thanks Steve
Old Jul 29, 2014 | 11:59 AM
  #47
ke5rbd's Avatar
ke5rbd
It really does say that in the SE catalog. Left out about it would pull away in a 0 to 60 sprint or 1/4 mile drag
Old Jul 29, 2014 | 12:11 PM
  #48
Eshaw301's Avatar
Eshaw301
I am afraid I disagree with you on no bolt in cam will beat a 255 from idle to 4000. For one the 222 will beat it from 2200 on up for sure...
Like I said before, there isnt a bolt in cam on the market that will beat a 255 from idle to 4000 rpm. Hell...on a 96" motor, the 255 is at 80-90 foot pounds at around 2000 rpm. Thats on a 96 inch motor. Like I said before...are there better cams out there than the 255? Of course. But is there a cam out there that performs better than the 255 for what it was designed to do? Stump pulling torque on a stock motor from idle to 4k rpm? I have yet to see one that proves this. The 222 is an awesome cam....it may be going in my motor next week to replace the 777 that I have...but for off idle to 4k rpm performance, the torque curve of the 255 cant be beat. But hey...im no expert on anyones riding styles or preference. But if it were me, I would make the 255 standard on the touring bikes. Harley came close by offering it as an option...but to me it needs to be standard.
Also, what has changed in cams in the past 3-4 years? I can only think of the 222 as a new offering. Everything else...andrews 48 and 57, 555, and a few others have been around for years. So no, things have not changed. And yes...if you give Jamie at fuel moto a call, he will confirm what I said about the 255 being a better off idle cam than the 222. But...like you mentioned...from 2200 on up, its not even close....the 222 would crush it hands down. Im not knocking any cam or anyone's decision but I still gotta give credit where credit is due. The 255 is an awesome bolt in torque cam. Would I do one? Probably not seeing as tho I had a pair in my hands and sold them for the 777s. I am definitely pulling the trigger on the 222 real soon.
Old Jul 29, 2014 | 12:12 PM
  #49
ke5rbd's Avatar
ke5rbd
If not doing any other mods I would go with the SE204 as it only has .508 lift and is much easier on the stock valve train. If planning other work like lifters and head work the TW 222 with .555 lift would out do it then. With stock heads the 204 and 222 would be side by side. A properly tuned 14 limited with 204 should do about 95+ hp and 112+ torque. Long as the cruise and lowend is right it is hard to tell the difference between 3 or 4 hp and 5 or 6 torque at WOT. Which ever you decide send me a PM and I will send you a map that will get you off to a good start.
Old Jul 29, 2014 | 12:18 PM
  #50
Eshaw301's Avatar
Eshaw301
You already answered your own question.
