Oil leak 12 FLHX
Old Jul 26, 2014 | 03:14 PM
Night Crawler's Avatar
Night Crawler
Well then, that gets back to the "Whole Lotta' Shakin' & Heat Going On" !
Old Jul 27, 2014 | 02:30 PM
HDchrome's Avatar
HDchrome
You guys hit it right on the head. It was those 2 bottom cap screws on the tranny right side cover where the exhaust bracket attaches. I had previously checked all the other screws on that cover and they were tight, so assumed the two bottom ones that I couldn't get to were also tight. Wrong. Got the ball end of an allen wrench on them, and they turned easily. That's good, found the problem. Tightening them up took a bit longer. I used a small right-angle ratchet screwdriver that took 1/4 inch bits. Cut off a short piece of 1/4 allen, put it in the ratchet screwdriver like a screwdriver bit, and got that in there. That got it tightened up real well. Wiped off everything with brake cleaner, put new wax on the exhaust cover and air filter cover (I changed the element, it was nasty), and its now good to go.
Thanks guys, much appreciated.
Old Jul 27, 2014 | 05:05 PM
TWIN CAM 96's Avatar
TWIN CAM 96
+3 or 4
Old Jul 27, 2014 | 07:09 PM
acchd's Avatar
acchd
Cool glad you got it resolved!
Old Jul 27, 2014 | 10:49 PM
mcain49's Avatar
mcain49
Originally Posted by lp
+1
lp
+2 Mine leaked in same place. Very common leak experienced by many on this forum.
Old Jul 27, 2014 | 11:13 PM
DresserDude's Avatar
DresserDude
Worthless Harley dealer gave me a new clutch cable and f'd with that bracket. I went for a pretty substantial ride and guess how much oil was lost/ended up putting in my 2011 Ultra? Give up? over 28 ozs. I was PISSED!!!
08ElectraNY
Mar 9, 2016 08:32 AM
steelerdude1
Jul 7, 2015 11:31 AM
rperk60
Oil Archive (no new posts)
Jul 29, 2013 04:57 PM
gabrown44
May 4, 2010 07:45 AM
dynadiver
Nov 17, 2007 11:13 PM
