Bank Sensor - DTC's - Adding Lights on 2014
Old Jul 28, 2014 | 09:17 AM
p51bombay's Avatar
p51bombay
Default Bank Sensor - DTC's - Adding Lights on 2014
So on Saturday I plugged the new turn signal light bar into the tail light to test it before installation. Ran the hazards for a bit first then tried the left/right signals which both worked as they should along with the tour pak lights - Great!
Added air to the new Agitator wheels since both were a little low from mounting. Put about 10lbs in front and 4lbs in the back.
Sunday I went to back out of the garage and the milk crate I sit on wasn't quite clear and got caught under the RH slip on which leaned the bike to the left in the doorway. I managed to catch and hold it but I couldn't go forward due to a lip, couldn't go back, couldn't get the stand down and apparently once it leans so far the horn no longer works so no way to summon the wife to come move the dammed milk crate. No choice but to set it down - nothing damaged other than pride of the last several bikes never touching ground - oh well, bound to happen with 900lbs.
Once on the road, I noticed that the 6th light wasn't coming on, no other issues, lights, turns, cruise all normal. On the way back I stopped to check for DTC's and found several.
BCM:
b2151
b2156
-both related to rear turn signals which is no surprise as I had plugged in but removed rear light bar.
ABS- UO 100
-lost communication with BCM
RAD (assuming this is Radio)
b1306 - Infotainment lost comm.with hands-free phone module
- I have iphone plugged in but no hands free at this time.
Cleared all the codes, rode the last few miles home and checked them again - non returned but still no 6th light.
So is any of this related to the tip over? Could adding air to the new wheels/tires have thrown things off and maybe I need to adjust the primary ratio with the Power Vision as I did with the TTS on my Dyna? Thoughts and opinions appreciated - trying to avoid taking to dealer as they are quite a ways away.
Old Jul 28, 2014 | 08:03 PM
p51bombay's Avatar
p51bombay
Evening bump - anyone?
Old Jul 28, 2014 | 08:12 PM
Thor183's Avatar
Thor183
Well it might be worth a shot just to see what happens when you pull the main fuse , and disconnect the battery and then hook it back up? If nothing then it's back to the dealer since it's under warranty.
Old Jul 28, 2014 | 11:27 PM
p51bombay's Avatar
p51bombay
Going to try that - I'd like to avoid the dealer due to distance from home.
03nighttrain
2014-2024 Touring Models
Aug 1, 2019 03:02 PM
ChaseDWG
Electrical/Lighting/Alarm
Nov 14, 2018 12:36 AM
ChaseDWG
Nov 13, 2018 08:47 PM
Ryan C
Jun 10, 2016 10:32 PM
Da Shadow
Mar 11, 2012 01:18 PM
