2008 Ultra Classic
Old Jul 28, 2014 | 04:53 PM
dcun1953's Avatar
dcun1953
Stage II
Default 2008 Ultra Classic
Took my bike for the 30,000 mile maintenance and the Master tech is telling me that it sounds like i need to replace my Stator and possiable starter!!! He said i wouldn't believe how many he has already changed!! Cost is about 1,200.00. Any suggestions??
Old Jul 28, 2014 | 05:01 PM
navyman's Avatar
navyman
On my 2008, my primary bearing went out at 68,000 miles. I sold it at 71,000 miles with original stator and starter.
Old Jul 28, 2014 | 05:06 PM
Weavr99FLHT's Avatar
Weavr99FLHT
What does a bad stator sound like? did he follow the appropriate testing procedure? Or is he that good?
Old Jul 28, 2014 | 05:07 PM
dawg's Avatar
dawg
Originally Posted by dcun1953
Any suggestions??
What leads him to say "sounds like" replace stator? Anyhow, you can replace a boatload of parts yourself for the $1200. If you indeed need a stator and/or a starter, do it all yourself. Replace IPB, compensator, gaskets, tensioner, etc for about $800.
Old Jul 28, 2014 | 05:27 PM
wndchsr2's Avatar
wndchsr2
I am curious what sort of sound a stator makes when going bad? I may be wrong but that "sounds" like BS.
Old Jul 28, 2014 | 06:19 PM
dcun1953's Avatar
dcun1953
Stage II
When you try to start the bike it sounds like the starter is engaging and letting go before the engine starts and then re-engaging. Gears are skipping and grinding. Does not do it every time but 1 out of 5 cranks it will.
Old Jul 28, 2014 | 07:13 PM
grout's Avatar
grout
just had mine done on 08 EG Classic - $900.00
Old Jul 28, 2014 | 07:34 PM
dawg's Avatar
dawg
Check starter clutch, check compensator, check ring gear. Sounds like starter clutch.
Old Jul 28, 2014 | 07:43 PM
wndchsr2's Avatar
wndchsr2
Do you still have the stock compensator? Because I have had two compensators on two different bikes replaced at roughly the same mileage........Around 35K miles. Both situations sounded very similar to what you described.
Old Jul 28, 2014 | 07:49 PM
jeffreydsilver's Avatar
jeffreydsilver
If it ain't broke, DON'T FIX IT! Fix the starter (replace it) and move on.
