V bad performance while hot
Old Jul 30, 2014 | 06:40 PM
JoeN's Avatar
JoeN
Default V bad performance while hot
hello
I recently posted a problem with my 2010 ultra that runs like **** when hot. I get no throttle response, and then it lunges, almost like having bad gas. It is not the gas, and it is down right dangerous and embarrassing.
People told me to clean the tcm, behind the air cleaner, and the ecm. I cleaned both, and used dielectric grease. I am still having the problem.
I have taken it to a dealer, but since the engine light came on only once briefly, I am told it is not throwing codes. The Harley tech is having a hard time diagnosing the problem.
Does anyone out there have any ideas. I would GREATLY appreciate input. I don't want them throwing parts just for the hell of it
thanks
JoeN
Old Jul 30, 2014 | 07:45 PM
mkguitar's Avatar
mkguitar
electrical problems such as sensors are often affected by heat/cold.
common for diagnostics to apply heat with a heat gun, or cold with a spray can to individual sensors.
usually a code will be recorded if the ecm thinks a sensor is bad- or gets unexpected data
does you bike have any mods- if so, list them
oh, and one more thing some grips ( krapkin) had trouble with the internal mating gear breaking inside the grip- causing loss of throttle control
mike
Old Jul 30, 2014 | 07:58 PM
RoadKingCop's Avatar
RoadKingCop
My city-bike (2013 Police RK) does that. Runs great when cool, but in the heat of the day, during stop and go traffic, it just barely pokes along. No lights yet though. It seems to go into EITMS rather quickly too. My 08 FLHT has never had a problem.
Ben
Old Jul 30, 2014 | 08:08 PM
TcHunter's Avatar
TcHunter
Any chance there is settlement in the tank? I am just throwing things out. Fuel pressure regulator, grip sensor, throttle control actuator, fuel level sender. I may be way off but some ideals.
Old Jul 30, 2014 | 08:10 PM
JoeN's Avatar
JoeN
Default 2010 ultra mods
mkguitar
the only mods are a screaming eagle air filter with the hd down load, and rhine hart true duals.
I had added a new sound system, oil cooler, audible alarm, power outlet, BAL 1, but nothing major. Thats it I believe. Had it since new. Now 10,800 miles
This just started happening doing riding around town, slow speed stuff. When I took it to the dealers about 45 min. on the highway, doing 80-85, on a cool morning it was good, then off the highway it was still pretty good, but i think if I kept riding into town it would have acted up
To put the sound system in, I took off the gas tank to run the wires. I don't think that is a factor
thanks
Old Jul 30, 2014 | 08:18 PM
JoeN's Avatar
JoeN
oh, I added heat deamons 2 yrs ago
Roadkingcop. You know exactly how the **** rides, but mine doesn't go into EITMS. I didn't program it
I never ran the gas low and only use good gas. thanks
Old Jul 30, 2014 | 08:21 PM
RoadKingCop
Well, there's no question about it; I use **** gas. City will only spring for the crappiest stuff... mo-go.
Ben
Old Jul 31, 2014 | 04:32 AM
'05Train's Avatar
'05Train
The ECM pulls timing when the bike gets hot. Less timing=more heat and poor running.
Old Jul 31, 2014 | 05:29 AM
nevets61's Avatar
nevets61
Its a long shot but in the event the quick disconnect under the tank is closing some when hot, pull the fuel line quick disconnect loose and reconnect. See if the problem still exists. Sometimes those valves in the fitting need to be cycled.
Old Jul 31, 2014 | 08:38 AM
JoeN's Avatar
JoeN
05train
so what do I do, go for an auto tune. What kind. Thunder max? Quite pricey. I am a good old poor boy on compensation, and this is the only thing that keeps me quite sane when I can ride
nevets61
I will try that
