Terrified...
Old Apr 6, 2007 | 11:45 AM
BusaToHog's Avatar
BusaToHog
6th Gear
Default Terrified...
I started up my 06 SG this morning for my first ride of the season. It' s only got 1800 miles on it. When I started it up I heard a knocking/clanging sound while the engine was idling. By time I got to work, the sound has stopped. I am very mechanically declined, can anyone tell me if I should be really worried or what?
Old Apr 6, 2007 | 11:49 AM
chesterbud's Avatar
chesterbud
Default RE: Terrified...
Only thing I can think of is that if the bike has sat for a long time the oil had drained off the surfaces and it started "dry". I've not had mine do that but just a thought!!!
Did you check your oil??
Old Apr 6, 2007 | 11:50 AM
huffhuff's Avatar
huffhuff
primary chain may need adjusting. my neighbor's 03 needed adjusting sevral times in the first couple of thousand miles. it can get quieter when it warms up.
Old Apr 6, 2007 | 12:34 PM
gunrunner's Avatar
gunrunner
Its best to start bikes at least once a month while in storage or you could pull the plug wires off and let it turn over some with the starter to get the oil flow going then put the wires back on and start it. Also using a good syn oil (not syn3) will keep the parts better lubed during long periods of not being run.
Old Apr 6, 2007 | 12:36 PM
Mr Wonderful's Avatar
Mr Wonderful
Hmmmm. Has it done it again in a cold start? If it makes all this noise as you say on cold starts, let it warm up and ride it to the service department. You might check for loose exhaust clamps, etc. before you get too worried. I've traced an odd rattle or two to those exhaust clamps......and one to a muffler hanger bracket squeak. Stuff happens!
Old Apr 6, 2007 | 12:47 PM
electaRICK's Avatar
electaRICK
how many mice did you leave homeless?
Old Apr 6, 2007 | 01:44 PM
BusaToHog's Avatar
BusaToHog
6th Gear
HAHAHAHAH - now that is funny!
Just that I bought it last year and put very few miles on it (job prohibited life in general)
Now it is spring and I have a new job and plan to start riding every day!!
Thanks for the advise, I will keep an eye on it.
Old Apr 6, 2007 | 01:46 PM
xxxflhrci's Avatar
xxxflhrci
You had a lifter bleed down. Info on it should be in your owner's manual. It is addressed in the manual for my 2000. No big deal. You hurt nothing.
Bulldog1085
Shovelhead
13
Sep 12, 2022 02:26 PM
Lancemchn
May 7, 2013 04:01 PM
masterblaster
Oct 4, 2009 01:21 PM
kaptekarev
Panhead
11
Jul 4, 2006 10:07 AM
mchaous
Oil Archive (no new posts)
24
Mar 15, 2005 11:34 PM
