Crankcase Vent Pressure
Old Aug 1, 2014 | 11:29 AM
SBates08's Avatar
SBates08
Default Crankcase Vent Pressure
Is there any way to check the crankcase breather on a twin cam to see if they are clogged and not venting properly? I'm still trying to determine why I'm getting Blue Smoke from my rear cylinder exhaust. It only does this after the bike is hot and an extended idle. Once on the throttle there is one good puff of smoke and it's gone until I stop again. Compression tests were good at 190 and 195. Leak down tests were good also with only 9% leak down in both cylinders. Bike used almost a quart of oil on a recent 700 mile round trip to Baton Rouge. Was in a lot of stop n go traffic as well. Dealer keeps insisting that my tune is causing the smoke but I'm not buying that. I'm running a custom map on my PV from Dragos Bike Works and the bike runs and performs flawlessly other than this. For what it's worth, the bike will still smoke with the stock tune and a/c on as well. Any thoughts or input cause I surely need all the help I can get.
2010 Limited with some stuff
Old Aug 1, 2014 | 11:49 AM
mkguitar's Avatar
mkguitar
oil is more white smoke.
smoke on accel is worn piston rings/ bad piston to cylinder seal
smoke on decel is worn valve seals ( the high motor vacuum when the throttle is closed will suck oil past bad seals- these valve seals are protected from the combustion by the valves when closed)
just pulling your dipstick would relieve any pressure in the crankcase if you think the system is over pressured- try testing with dipstick pulled.
but oil burning makes white smoke, not black or blue
black smoke is unburned gasoline
mike
Old Aug 1, 2014 | 11:53 AM
nemick's Avatar
nemick
Sounds overly rich perhaps, at least at idle.
Old Aug 1, 2014 | 11:58 AM
SBates08's Avatar
SBates08
Ok then this would be a whiteish blue smoke. Most definitely not black.
Old Aug 1, 2014 | 12:02 PM
mkguitar's Avatar
mkguitar
using any additives like "seafoam" ?
some additives do not burn completely ( see my post on seafoam and failing emissions testing...) and could make the "black smoke" of a rich mixture appear more blue/white
lost oil- it's not showing up in the primary is it?
Mike
Old Aug 1, 2014 | 12:12 PM
SBates08's Avatar
SBates08
Originally Posted by mkguitar
using any additives like "seafoam" ? some additives do not burn completely ( see my post on seafoam and failing emissions testing...) Mike
No sir, no additives at all. Here's my thought process on this and feel free to tell me if I'm wrong. If there is too much pressure it will find the easiest way out first which would be the valve guides or seals which would explain the smoke. If this is the case could the excessive pressure hinder the closing of the valves? If so this would explain the stumble in the exhaust note at idle. Seems plausible to me or do you think I'm overthinking things. I'm running out of things to check.
Old Aug 1, 2014 | 12:13 PM
SBates08's Avatar
SBates08
Not in the primary either.
Old Aug 1, 2014 | 12:14 PM
mkguitar's Avatar
mkguitar
pulling the dipstick will "unseal" the closed system
really unlikely that anything would hinder the valve closing- the valve springs are very strong
mike
Old Aug 1, 2014 | 12:20 PM
SBates08's Avatar
SBates08
pulling the dipstick will "unseal" the closed system really unlikely that anything would hinder the valve closing- the valve springs are very strong mike
I'll give this a shot. If this stops the problem...then what's the cause?
Old Aug 1, 2014 | 12:37 PM
mkguitar's Avatar
mkguitar
you got me...
if you were to think that your seals are hardened and not pliable...you could try a auto tranny stop leak additive.
what these do is swell the seals in a tranny to stop leaks, the swollen seals are more pliable.
but like any magic potion the results are temporary. ( and most of these are just rubbing alcohol, so you don't want that displacing oil in the bearings-)
but that might tell you if your umbrella valves are bad- i doubt it though
as far as a stumble or un-even idle- if you have mods- the more mods the more variables.
and are you experiencing a warning of impending doom? or just a new-normal?
you could try just using the sole of your boot to block part of the exhaust outlet while idling, see if that changes anything- if so you could be seeing the results of a harmonic pulse in the exhaust- which will always be very rpm specific and may occur again at 2x and 4x the observed rpm
mike
