backrest
Old Aug 4, 2014 | 04:06 PM
Ragtop's Avatar
Ragtop
Mustang is the best IMHO! I use it with my sundowner.
Can't use it on the Corbin though, wish there was some way to make
a Mustang backrest fit a Corbin seat!
Old Aug 5, 2014 | 10:23 AM
SmokerMI's Avatar
SmokerMI
There is no doubt that Mustang has a great reputation.
With that said though I think I would prefer the added flexibility of the HD adjustable mount so that I can adjust as I am riding.
Now I just have to try and figure out the difference among the many backrest pads that I see on the HD web site. Any thoughts would be appreciated.
Old Aug 5, 2014 | 11:57 AM
03snake's Avatar
03snake
I REALLY like the HD adjustable I put on the Sundowner seat on my SG. I make 'on the fly' adjustments and it solved my lower back cramps. I actually found another thread here somewhere that suggested adding a nut on each side at the front of the mount between the mount and the fender. It allows more rear movement of the backrest.
Old Aug 5, 2014 | 12:02 PM
03snake's Avatar
03snake
I'm 5'11" and use the lowest position of the height adjustment. After a ride I also push the backrest all the way back to take the pressure off the front of the slit opening. Here are the pics of the nut's I installed. I needed longer bolts to do this:
Old Aug 5, 2014 | 12:11 PM
03snake's Avatar
03snake
There are only 5 pads available for the adjustable backrest. Pick the one that matches your seat the best? I used the smooth style one. You will find the backrest a little wobbly but I find it actually helps position it better on your back.
Old Aug 5, 2014 | 12:55 PM
GTK's Avatar
GTK
I suppose your recent backrest gave you more support in the upper back area.I have the HD manual adjust one.I am 6'2" and have it in the lowest position with two higher positions to go if needed.Has worked great for 150-200 mile rides between stops.
Old Aug 5, 2014 | 11:16 PM
Fishrrman's Avatar
Fishrrman
You might also check one out called the "Utopia" backrest. It has a rectangular pad (larger than Mustang's or HD's) and a map pocket attached to the back of it...
SWMB
2014-2024 Touring Models
Dec 28, 2018 01:25 PM
billbrummett
Milwaukee Eight (M8)
Mar 30, 2018 02:45 PM
Tek74
Jul 10, 2011 08:46 PM
joeschmoe
Mar 14, 2008 10:12 AM
Timex
Oct 29, 2007 11:44 PM
