inner fairing help
Old Aug 7, 2014 | 07:16 AM
treilly's Avatar
treilly
I have been using the windshield bolt for two years. No issues. The washer gives you a bigger surface so it won't suck through unless you wrench on it. The other thing is its the same torx size.
Old Aug 8, 2014 | 03:32 PM
papa_j's Avatar
papa_j
Thanks for all the input. Not near a harley shop to pick up windshield bolts. So sitting in my shed looking at it for an hour, here's what I did. Had an old plastic battery box. Cut a strip off about 3 inches long. Heated with a bic lighter just enough to bend into "s" shape, not melt. Scuffed up both surfaces with some sand paper. Placed s shaped plastic piece behind bolt hole inside of fairing. Used some jb weld plasti-weld to secure it. Drilled a hole through the plastic. Then had to grind the steel fastener that bolt goes into, just enough to match width of s shaped plastic piece. It worked! Holds tight. Gonna go ahead and do the other side also.
I appreciate every body who gave advice, and if this ever happens to anyone else, hope they can use this thread.
Old Aug 8, 2014 | 03:41 PM
my67pnycar's Avatar
my67pnycar
So it wasn't the brass inserts?
No Tyme
Jun 18, 2018 03:12 PM
ShrinerRider
Aug 17, 2017 12:42 PM
kryingame
Apr 3, 2017 02:35 PM
AlanStansbery
Oct 19, 2013 11:56 PM
ral819
Aug 4, 2011 05:46 AM
