brake pad life?
Old Aug 6, 2014 | 02:30 AM
skipperhd1's Avatar
skipperhd1
Cool brake pad life?
hi guys! i've got a 2006 road king with 19,000 miles on the clock. i'm a road rider and want to know the life of the brake pads. any good aftermarket parts and can i save some money? cheers from montana
Old Aug 6, 2014 | 06:37 AM
sfcmo357's Avatar
sfcmo357
I can't really answer your question but I think alot is determined by your riding style. I'm not a heavy braker....I'm from the school of "downshifting" and allowing the engine to do the bulk of the braking. There are many instances when I only use my brake for the last few feet of a "NORMAL" stop because I downshift alot.
Old Aug 6, 2014 | 06:44 AM
Greezey Rider's Avatar
Greezey Rider
Yes...It does very much depend on your riding style. I can go through a set of pads in a very short time (front pads in particular) when I run hard.
If I ride easy, I can get 20,000 miles out of them.
But they're cheap and easy to replace, so I use'em hard!
Old Aug 6, 2014 | 10:21 AM
lionsm13's Avatar
lionsm13
Many of us use Lyndall Z Plus that we buy from Drew @ Hog Pro.
They're a sponsor or this forum.
Check em out.
Old Aug 6, 2014 | 10:34 AM
Hogpro's Avatar
Hogpro
Former Sponsor
I'm more of an engine braker as well. I don't use my rear brakes. I put the LRB Z Plus pads in my bike at 5000 miles and I am now at 23500 miles. They still have plenty of pad left. I am thing probably another 10K before I need to change them.
Old Aug 6, 2014 | 10:46 AM
dsigrist's Avatar
dsigrist
I'm just about to replace my first set, front and rear, on my Road Glide at 35k. It all depends on how you (or the original owner) ride. Harley says replace them at .016 but I typically error on the side of replacing them before they get quite that thin.
Old Aug 6, 2014 | 12:16 PM
Duc's Avatar
Duc
Like others have said all depends on how and where you ride. I have 40k on my stock HD pads and they have life left, I've got new pads ready but probably go another 3-5k before I replace.
Clif
Old Aug 6, 2014 | 12:21 PM
dochawken's Avatar
dochawken
I have 22k on my oem pads, they look great...
Old Aug 6, 2014 | 12:55 PM
Krutch's Avatar
Krutch
From: somewhere in "The Peoples' Republic of Illinois
As noted, riding style has the most effect on pad life. I have 51,000+ on my FLHT and I've changed the rear pads with almost every rear tire change (5 tires total). Have second set of pads on front. I use the rear mostly but downshift for slowing so the pads don't last as long back there.
You can look at the pads from underneath to see how thin they are. Never let them wear into the steel backing. Pads are cheaper to replace than most rotors.
No matter how pretty, fast or radical your bike is it has to stop when you really NEED it to! Always remember: "What's your life worth!"
Old Aug 6, 2014 | 01:56 PM
69cj's Avatar
69cj
I personally use the brakes over down shifting. I figure brake pads are cheaper and easier to replace than clutches and drive belts. Opinions are what makes the world go round as long as they only affect the one making them.
